Results 1 to 4 of 4
Thread: What tyre pressure do i need
    Aug 2018
    Hi guys I know it's a silly question but I have a 2018 tiguan r line with the 19 Tyres so what pressure do I have them at its at 44 right now is that to high or to low thanks.
    May 2007
    Quote Originally Posted by xSTIGx View Post
    Check your tyre placard in the Fuel Flap (or B Pillar - door sill).
    Then adjust (when cold) and enter / store the values in the settings menu.
    Simple...
    Aug 2018
    Those figures in the placard - are they the recommended pressures or recommended minimum pressures?
    2018 Allspace 162TSI R Line
    Mar 2017
    Tasmania
    They are the recommended pressures.
    tyre pressures aren’t a black art - load inflation tables tell you what pressure to run for tyre size and load. All tyre manufacturers the same reference set.
    Here is a table for your reference: https://www.toyotires.com/media/2125...s_20170203.pdf
    they are manufacturer agnostic - doesn’t matter which one you choose- the important parts are the tyre construction (eg P or LT), tyre size, and load.
