I have always used water
Just plain old water![]()
Sent from my SM-G950F using Tapatalk
You might get algae in the bottom of the washer bottle, which may block the pump and squirters.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Here is an old thread of mine with some images of the stuff I'm using. Doesn't sound like the same stuff. Do you ahve a picture of the bottle?
Source: Volkswagen Washer Fluid
And one of the replies which talks about something different again!
G055184 A1
Concentrated Screen Wash Summer 1: 100 Original VW Audi Seat Skoda Wischwasser (G055184 A1: Amazon.co.uk: Car & Motorbike
There is also this Russian page which shows a few other variants:
Летние концентраты VAG — бортжурнал Volkswagen Jetta 1,4 TSI 122 л/с+DSG7 2014 года на DRIVE2
I'm at a dealer tomorrow so will try to remember to ask about these things![]()
That's the one mate, its cheap enough and seems to last a fair while. All you do is fill up the top chamber, and use that to top the entire fill bottle (mixed with water of course).
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
Are you serious. Water does the trick and if you really feel the need some glass cleaner.
Is the overuse on MY17 models because it's also got the front light washers?
I can't imagine why it'd be using much otherwise.
That's a lot of info there! I suppose I'll check in with dealer on their price per bottle here. But I guess a lot of washer fluids seems to be drained up by headlights, not sure why the settings is set to wash headlamp like once every 2nd time the window washer is pulled?
Thought about just adding water, but it just doesn't clear the glass as great, especially in cold conditions.
