VW have their own genuine fluid.
I just buy the no-name stuff in bulk from Supercheap. Does the job just fine.
So just 6 months & 6~7000km into my Tiguan now, I started receiving the "Low Washer Fluid" warning on Monday, which is much quicker then I had anticipated as with my previous car took nearly 2 years for the washer fluid to be used up. Maybe I've been using it a lot recently since a lot of dirt has been covering my car during work, or I question if the dealer even topped the fluids up when I picked the car up after 1000km service.. but all that aside,
What brand does the VW group use for washer fluid? or anyone has good recommendations?
I'm currently looking into this as its selling for a cheap price here
Bluecol 3in1 Summer | Auto Express
'07 Transporter 1.9 TDI
'01 Beetle 2.0
I used the genuine stuff when mine did the same thing at about 7,000kms - just dropped into the local vw service and picked up a bottle which you dilute. Think it was $10 or something for the 1litre bottle.
The Genuine stuff gets diluted 1:4, so you get 5L out of one bottle. I actually have a designated 5L bottle (plastic fuel container with a spout) that I use to mix it up then top up both cars as needed.
For the Cabriolet it's probably less important since the lines only have to run to the front windscreen but for the Multivan they run all the way to the back so I always ran the genuine stuff to ensure if it ever gummed up/broke it would be warranty vs any discussion over the fluid.... but then I sort of just stayed in that habit even after warranty and still use it... I like it. It smells nice
Genuine retails around $5, as long as you dilute it as mentioned above
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
thats also a reason i used the genuine stuff - to avoid an argument if i ever got a blocked nozzle/line
I usually need to refill the washer bottle weekly! Lol
That said I have noticed that the headlamp washers use up a lot of fluid. Our old X5 had the biggest washer bottle I've ever seen and it would last a few weeks.
2017 VW Tiguan 140TDI Highline
2012 VW Touareg V6 TDI
1985 Mercedes-Benz 380SE
It's a bit of a shame they don't sell it in larger bottles. I used to just ask for a few every time I had the card serviced (when it was under a lease) so the costs would disappear into the servicing costs. I was building up a little stock pile which has seen me through the last couple of years post lease, although I'm down to my last couple of bottles at the moment.
Do you guys put VW air in the tyres too?
One born every minute.
Hey Hawk, I went and got a bottle off the shelf to read the instructions and it says its a concentrate of 1:100, the bottle being a 250ml.
Also, it has a little reservoir at the top of the bottle, that's used as a measuring device. So one small dose, will make up the entire fill container! So not sure why folks are running out so quick, perhaps it is being mixed incorrectly? I fill mine up once every few months and don't have any issues, however admittedly I don't have headlamp washers
Part# for reference is G 055 184 A1
