The feature Is in the VCDS to enable and disable you might of seen that but does not seem to work for me ounce enabled either.
Hi All,
New VW owner as of yesterday! I had a Renault Koleos until someone wrote it off... but now I have a tiggy!
WALK AWAY Locking
Any idea how to enable this? I have had a look and tried the app in my OBDeleven but I can't get it to work! I want to be able to walk away with the key and the doors to lock.
Thanks!
P.S. I have a 2017 VW Tiguan Comfortline with both packs.
Hmmmm interesting - Yes I enabled it in my OBDeleven as well...
I'm not sure if it a Highline only feature, but if you tap on the outside of the door handle, it locks. If you tap on the other side it opens. You need to have the key on you (ie in your pocket).
