Which models come with these tyres?
Didn’t know such a thing existed. I have always used a puncture repair kit it’s saved me about 6 trips to the tyre shop
Continental Tyres with ContiSeal looks like a complete marketing scam
Got a small screw within the 5mm limits as specified by Continental and the Tyre still leaked air
Tyre Technology - Sealing punctures with ContiSeal™
Worse still, when you take it in to get repaired, Tyre places say its a headache to remove the ContiSeal goo that is stuck on the inside and are hesitant to do the work.
Seems our friends in the UK have the same issue
ContiSeal tyres and a space saver? What's the point? - Page 3 - VW Tiguan MK2 Forums
Has anyone else experienced nail / screws in their Continental with ContiSeal Tyre's and they still leaked ?
2018 Allspace 162TSI R Line
Same, I had a roofing screw go into mine then took it to a tyre shop and they said these are a massive pain in the arse to repair.
I tried to pull out the roofing screw and it leaked air, so I pushed it back in and took it to a repair shop.
Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
Yes they did, but charged me $50 where as last time they repaired a normal tyre or was $30.
They use a proper mushroom to plug up the hole, ie remove the tyre plug it up, then back on. Other places just use that rubber strip thing (which you can do yourself).
This was done at Blair's Tyres Lansvale.
Did they have to scrape off the Tar Goo before they put in the plug ?
I wonder if the Continental with ContiSeal comes with any sort of warranty ?
Or if this should be covered under VW warranty as they are the seller ?
"Tyres
Any claims in relation to tyres.
Note: Tyres may be covered by warranties offered by individual tyre suppliers.
Your authorised Volkswagen Dealer may be able to assist you with claiming
this warranty from the supplier. If a tyre is found to be defective within the
New Vehicle Warranty period, it will be assessed on the nature of the defect
and the percentage of wear incurred. Where tyres are covered by a warranty,
the warranty may not be the same length as the New Vehicle Warranty.
Wear and tear
Any parts and accessories that wear out as part of their normal operation
(e.g. clutch linings, brake discs and pads, brake linings, wiper blades, globes
of all types (excluding bi xenon and LED), fuses, trims, diesel particulate
filters, catalytic converters, all belts, tyres, spark and glow plugs, shock
absorbers, wheel bearings, and ball joints, filters, fuses, dry cell batteries,
satellite navigation update discs, textile and rubber floor mats, gas struts,
cargo liner, tub liner and all other parts and accessories of your vehicle that
have been subject to normal wear and tear."
