Results 1 to 10 of 16
Thread: VW Tyres - Continental with ContiSeal - Absolute Rubbish
    Apr 2018
    Thumbs down VW Tyres - Continental with ContiSeal - Absolute Rubbish
    Continental Tyres with ContiSeal looks like a complete marketing scam
    Got a small screw within the 5mm limits as specified by Continental and the Tyre still leaked air
    Tyre Technology - Sealing punctures with ContiSeal™
    Worse still, when you take it in to get repaired, Tyre places say its a headache to remove the ContiSeal goo that is stuck on the inside and are hesitant to do the work.
    Seems our friends in the UK have the same issue
    ContiSeal tyres and a space saver? What's the point? - Page 3 - VW Tiguan MK2 Forums
    Has anyone else experienced nail / screws in their Continental with ContiSeal Tyre's and they still leaked ?
    Aug 2018
    Which models come with these tyres?
    Didn’t know such a thing existed. I have always used a puncture repair kit it’s saved me about 6 trips to the tyre shop
    2018 Allspace 162TSI R Line
    Sep 2011
    Melbourne, Victoria
    Quote Originally Posted by FastMitch View Post
    Had a nail in the side wall of one of my fronts last week, went with the conti 101Y AO front replacements as they were both due for replacement..
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
    Apr 2018
    Quote Originally Posted by iDiesel View Post
    I think you'll find that is for off-road massive tyres. Can't see this working well on thin 20" tyres.
    >> YouTube
    If you need to do it as a DIY, this kit looks better
    >> YouTube
    Which models come with these tyres? Didn’t know such a thing existed.
    Neither did I until I got the screw in the Tyre. Model is a Tiguan Highline RLine
    Oct 2018
    Melbourne, VIC
    >> YouTube
    >> YouTube
    I’ve never had to use it, but the Mini Cooper comes with a repair kit by default, as there’s no space for a spare wheel.
    Not saying it’s a good alternative, but an alternative (for non 4WD’s) nonetheless.
    Same, I had a roofing screw go into mine then took it to a tyre shop and they said these are a massive pain in the arse to repair.
    I tried to pull out the roofing screw and it leaked air, so I pushed it back in and took it to a repair shop.
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
    Apr 2018
    Quote Originally Posted by Dose Pipe Sutututu View Post
    Did the Tyre shop repair it in the end ?
    Yes they did, but charged me $50 where as last time they repaired a normal tyre or was $30.
    They use a proper mushroom to plug up the hole, ie remove the tyre plug it up, then back on. Other places just use that rubber strip thing (which you can do yourself).
    This was done at Blair's Tyres Lansvale.
    Apr 2018
    Did they have to scrape off the Tar Goo before they put in the plug ?
    I wonder if the Continental with ContiSeal comes with any sort of warranty ?
    Or if this should be covered under VW warranty as they are the seller ?
    "Tyres
    Any claims in relation to tyres.
    Note: Tyres may be covered by warranties offered by individual tyre suppliers.
    Your authorised Volkswagen Dealer may be able to assist you with claiming
    this warranty from the supplier. If a tyre is found to be defective within the
    New Vehicle Warranty period, it will be assessed on the nature of the defect
    and the percentage of wear incurred. Where tyres are covered by a warranty,
    the warranty may not be the same length as the New Vehicle Warranty.
    Wear and tear
    Any parts and accessories that wear out as part of their normal operation
    (e.g. clutch linings, brake discs and pads, brake linings, wiper blades, globes
    of all types (excluding bi xenon and LED), fuses, trims, diesel particulate
    filters, catalytic converters, all belts, tyres, spark and glow plugs, shock
    absorbers, wheel bearings, and ball joints, filters, fuses, dry cell batteries,
    satellite navigation update discs, textile and rubber floor mats, gas struts,
    cargo liner, tub liner and all other parts and accessories of your vehicle that
    have been subject to normal wear and tear."
    No idea TBH Mitch, but all my tyres are nearing the tread indicator so I didn't mind too much.
    Will be replacing them all with something else, either Bridgestone RE003 or Hankook RS-4 (if that make it in that size) or similar
