8 vag cars in family 6 drivers, none in 12 years ever complained about the key.![]()
Actually the remote start isn’t illegal here. Vf commodores had it and I’m fairly sure several USA cars and luxury euro’s do too.
"The law states once you park your vehicle on a road or car park, drivers must apply the parking brake effectively, switch off the engine if you are going to be more than 3m away from the vehicle.
"The keys must also be removed from the ignition."
As well as doors, windows must also be secured when a driver is more than three metres from a vehicle.
If you walked up to it start it and get in would be hard for them to book you but if you started it and stood away and talked you could be in trouble
Looks like the legislation varies from state to state. Victoria mentions the vehicle actually running whereas NSW only mentions removing the keys from the ignition, which obviously isn't applicable to keyless remote start.
I can now see why VW didn't bother with the remote start in AU. Probably to avoid legal troubles, even though Holden and other manufacturers offer it.
yep, as is the case with all traffic regulation - there are no federal traffic laws, only state and territory. Some rules are the same, but most differ in subtle ways.
Remote start is a peculiarly Canadian and (mostly northern) US feature. Holden only offered it because it was included for US-spec Pontiac vehicles that Holden built for export - it cost them literally nothing to offer it locally.
