Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Vibration sound at certain rpm.
    Sep 2009
    WA
    Blog Entries
    1
    Took the VW Tiguan on a dirt track, light off-roading.
    Now I can rear a vibration noise in any gear, between 2000-2500 rpm (even in neutral). Above/below this rpm range it's fine. It started right after the car was bumped around. Not heavily, it's an SUV after all.
    I can hear it in the cockpit with doors closed, but not outside or with the doors open.
    There is no jolts or vibrating feeling, it's just a noise.
    Sounds like a bee buzzing madly.
    Any ideas what it could be or help me diagnosis?
    VW Tiguan 2018 162TSI Highline
    VW Polo 2015 81TSI Comfortline
    Pacific Paradise QLD
    I replied to you on WP
    Sep 2009
    WA
    Blog Entries
    1
    Thanks
    It sounds similar to the (except I can't hear it unless I'm in the car with doors closed)
    YouTube
    Sep 2009
    WA
    Blog Entries
    1
    Interesting development. Noise is not there when the engine is cold. Develops when it gets warm/hot. No signs of overheating
    Quote Originally Posted by anonymousmoose View Post
    Exhaust is likely touching a heat shield. Exhaust pipe expands slightly when hot so makes sense that it wont touch when cold. Pretty common on the Tigs to have rattling heat shields near the exhaust.
    May 2013
    NSW
    Have you gotten any closer to determining what it is?
    Something similar developed in my 162 Highline during a long road trip, has remained in the car ever since.
    Sep 2009
    WA
    Blog Entries
    1
    Quote Originally Posted by RaID View Post
    No, only happened yesterday. Booked in Wednesday.
    Why didn't they fix it under warranty?
    May 2013
    NSW
    I've got a service coming up, will raise it then. It hasn't annoyed me enough to get it sorted sooner
    Sep 2009
    WA
    Blog Entries
    1
    [*UPDATE*]
    I canceled VW to look at it.
    Drove the car home, noise was there at the rpm range described.
    Got back to the city, had the car engine cleaned.
    The I sprayed the undercarriage with my jet sprayer. Found an awful lot pebbles in the plastics under the car. Started smacking the plastics to loosen the stones. Jet sprayed what I could (I didn't have a ramp to crawl under the car).
    Sprayed around the radiator to dislodge more leaves. Pushed the noise dampening foam back in. Gave parts of the engine another jet spray.
    Result, no more noise during a 30 mins test drive, doing lots of 2000-2500 rpms.
    If the noise returns, I'll have another look (also planning to get some ramps to lift the car).
    Aug 2018
    I’ve heard about rocks in your head, but rocks in your plastic bits!!!
    Ha ha, great to see you got to the bottom of it.
    Nothing more annoying than noises in the car
    2018 Allspace 162TSI R Line
