Results 1 to 10 of 18
Thread: Vibrating Front Wipers
    Sep 2011
    Melbourne, Victoria
    My front wipers vibrate quite alot when in use, especially when on the freeway at 100 km/h.
    Looks like the wipers arms are in too much tension against the windscreen.
    Anyone else noticed this?
    Will get it looked at next week at my 5 week checkup.
    Dec 2008
    Sydney/Canberra
    New blades and a good clean of the glass generally sorts it out.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2007
    Brissy
    Yeah as Umai Naa says, clean the windscreen. I would try to wash the blades first rather than replacing, they can last years. Use soapy water to get rid of any oily stuff. Use of a decent additive in the washer water helps a lot too.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    I'd give the windscreen a clean, clay bar and treat with rain X.
    Also clean the blades as suggested.
    Then see how they go
    Sep 2011
    Melbourne, Victoria
    Blades are brand new under 3,000km old.
    Apr 2017
    Beachlands, Auckland
    Quote Originally Posted by INASNT View Post
    I had exactly the same issue - took it back to dealer and they replaced them under warranty - no problems since.
    Sep 2011
    Melbourne, Victoria
    Replaced just the blades? Did they have to adjust the tension of the arms?
    Erskineville, NSW
    Clean the windscreen with either a specialised windscreen cleaner / claybar, ajax or cheap toothpaste.
    Jul 2010
    Robina Gold Coast
    I had the same problem it ended up being the wipers were not sitting square to the windscreen , The Vw dealer had to slightly twist the wiper arms to square it up
    Mar 2009
    Melb
    Cleaning windshield and wiper blades is the first go then perhaps adjust the blade angle relationship with the windshield ( I did mine gently twisting the arm a small amount) If all fails replacing the blade with Bosch's aerotwin blades is popular in other vw forums.
    Tig 162 R-Line; Audi TT
