Everything on mine was perfect.
2017 Tiguan 162TSI Highline/R-Line
2017 Audi S3
Mine was fine bar a really odd fault in the carpet of the drivers footwell... like it was warn? there is an area about 10x4cm that is 'ruffled'and feels totally different to the rest of the carpet, I left it as it was a company car but I can imagine fixing it would have been a mission - everything out to change the carpet? (I would have asked for this if it was my car)
Oh man. I have just discovered what I think is a manufacturing fault on my Tiggy!
Passenger side rear door. The rubber piece on window. It looks like they did not install this piece correctly as there is a raised section.
The other rear door also has a little area on the bottom with a raised section...
I will raise this with my dealer.![]()
I'm not quite sure how to rotate the image, but if you were to rotate the image 90 degrees clockwise, you will be looking at the window in the correct orientation.
There is then a 'vertical' rubber line that runs down the window (separating the moving window to the static one) that rubber piece in my picture you can see that it is not flat as it should be.
I know it's hard to see. That's probably why I had missed it too during the pick up. I only noticed it from the shadow the lip created...![]()
