Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: USB Power For Phone
    Dec 2010
    Helensburgh
    USB Power For Phone
    My phone lives in the car along with my Kindle, they never leave it and I got sick and tired of cables running out of front 12V outlet to keep them charged. I had a bit of a think about the problem and in the end I took the rear passenger information display and 12V outlet off the back of the console and patched into the back of the 12V outlet using a Jaycar 12V outlet, plugged a USB power adaptor into that and it all got hidden when the display was put back together. The wires from the outlet run into the centre console box through a hole I drilled in the floor of the console box under the arm rest. I know it might be a bit OCD but the wires and where to put everything used to drive me mad.
    Aug 2016
    Sydney NSW
    Any photos of the finished work?
    Dec 2010
    Helensburgh
    I have never worked out how to post photos on this forum unfortunately, all the instructions don't seem to work though on other fora I have no issues at all. If someone can point to instructions that work I will post some but all you can see is two USB leads coming out of the floor of the box and with the lid closed nothing at all can be seen which was the aim of it all.
    USB Power For Phone
    Quote Originally Posted by Ozsko View Post
    Yep true, the websites tricky. Recommend downloading an app called Tapatalk. Search for the forum. Easiest way to post comments and upload photos direct from your phone. Also lets you save your favourite threads onto the home screen. Very handy. Be keen to see a pic too.
    Dec 2010
    Helensburgh
    My mobile phone doesn't have a data connection so that's out. I just don't know why this forum has to be so difficult and every other V Bulletin forum is dead easy. All help in this regard would be appreciated.
    Jun 2012
    Dee Why, NSW
    It's really easy with a desktop browser. Just click on the little picture button and you can choose to either point to a URL or choose a pic from your computer.
    Dec 2010
    Helensburgh
    I'll give it another go as that is the way it should work but the last time I tried it that method did not work.
    Pacific Paradise QLD
    " Quote My phone lives in the car along with my Kindle, they never leave it"
    Where do you park your car I need a Kindle and a new phone LOL
    Dec 2010
    Helensburgh
    The phone I got for nothing and the kindle has a password on it so no problem. As far as I am concerned I wouldn't shed a tear if the phone disappeared as I never use it and never get calls on it. When I retired from my job where I carried three of the damned things I swore off using them forever unless I absolutely had to so it lives in my car for emergencies only.
    Dec 2006
    Kilsyth, VIC
    Image hosting through the forums has always been questionable at best. It doesn't work at all for some people for no apparent reason, but works fine for others. Other sites I visit tend to use other 3rd party solutions or plugins to get the job done with varying degrees of success/integration. Every now and again I look into different options...
    There is actually one in the works at the moment which is getting close... but isn't quite there yet.
    On a side note. I'm also a little anal about these things and have wired in hard mounted phone mounts as well as power for dash cams in both my VW's.
