Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Tyre Pressure Tiguan
    Feb 2017
    South Australia
    I've had my 2017 Tiguan for 6 months now and I got a Tyre Pressure warning on the rear right tyre.
    I went to the servo and noticed that all tyres were at 38 PSI except for the one I got a warning on.
    Anyway, I reduced all tyres to 35 PSI which I believe is the recommended PSI but I still get a warning on the rear right tyre.
    I'm still getting this warning message.
    So...
    1. Do 2017 Australia Tiguans get tyre pressure indicators?
    2. This warning came up on my second 5 minute journey after I washed the tyres and gave them a good scrub. Is this coincidental?
    3. What tyre pressure do you guys set them too? Is 35 PSI the current recommendation?
    Oct 2016
    Artarmon, NSW
    The 2017 Tiguan do not get individual tyre pressure monitors. It does have sensors that track the difference in rotation speed of each axle.
    There is a menu option in the Discover Pro that allows you to "Set/Store" the "current" value and it then monitors the differences across each axle. The warning indicator would "pop-up" when the difference reaches a predetermined value.
    This process relies on you pumping up the tyres to a equal amount and then pressing the set button on the menu.
    A possible reason the tyre pressure warning has not stopped could be that you need to "reset" the value in the Tyre section of the Discover Pro menu.
    Regards,
    David
    Ordered: 2017 build date Tiguan 162 TSI Highline with DAP in Tungsten Silver and rear luggage tray. ETA: late April / Early May. I did not have to wait. I took delivery on 11 March 2017.
    Sep 2012
    You need to reset the TPM in the car settings in the media unit whenever you change pressures.
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
    Jun 2017
    North Sydney, NSW
    32psi on 235/55 R18 on my Highline.
    Looking for a softer ride around town. I hope that pressure is not too low and wearing too fast.
    Nov 2013
    AUS
    Quote Originally Posted by spacemannz View Post
    Have you noticed a softer ride with the lower pressures?
    I did read about Jaguar F-Pace's owners doing the same and noticing a significant improvement in the ride. No long term reports on tyre wear yet tho.
    Jaguar F-Pace Forum - View Single Post - Tire pressure - yikes!
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
    Apr 2017
    belgrave victoria
    I run 36 psi on my 235/35/19's have had them at 32 but took it to 36 notice no difference in ride but got slightly better fuel economy
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Erskineville, NSW
    If you get a low pressure warning on tyre A and tyres B,C & D are all a higher pressure then that means you probably have a slow leak in tyre A.
    If you continue with the same strategy of reducing tyre pressures down to the lowest common denominator then eventually you will have 4 tyres at zero psi.
    Dec 2017
    Castle Hill, NSW
    I've been setting mine to 260kPa hot so according to Bridgestone that should be about 245kPa cold which is right in the middle of the comfort and performance recommendations and seems to work well. PS I know I don't have Bridgestone tyres, but Hankook didn't have anything I could find.
    Jun 2017
    North Sydney, NSW
    Can anyone recommend a good quality, reliable tyre pressure gauge?
    I don’t trust the servo air pumps, they’re always beat up with leaky hoses and often don’t read the same pressure twice in a row.
    I’ve been meaning to buy a good quality one for years, but only see cheap crap in the stores.
    Dec 2017
    Castle Hill, NSW
    Hi spacemannz,
    there's a 2015 guide from Choice downloadable here: Choice Magazine's tyre gauge review | Latest News | HAIGH Australia PTY LTD
    It's top recommendation is the Dr Air Dial Tyre Gauge 10-75psi TG3 which you can get from Autobarn for $13 or do.
