The 2017 Tiguan do not get individual tyre pressure monitors. It does have sensors that track the difference in rotation speed of each axle.
There is a menu option in the Discover Pro that allows you to "Set/Store" the "current" value and it then monitors the differences across each axle. The warning indicator would "pop-up" when the difference reaches a predetermined value.
This process relies on you pumping up the tyres to a equal amount and then pressing the set button on the menu.
A possible reason the tyre pressure warning has not stopped could be that you need to "reset" the value in the Tyre section of the Discover Pro menu.
Regards,
David
