Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Tyre Pressure Tiguan
  1. #21
    May 2018
    Melbourne, Victoria
    What does it say inside the fuel flap?
    Do you feel 41psi is too high or too low?
    Seems too high- it’s higher than the recommendations. Though I tested them warm rather than cold so that may explain it.
  2. #22
    Erskineville, NSW
    2.6bar is 38psi. I wouldn't have an issue with 40-44psi cold. It would give some rim protection on our potholed roads.
    I certainly wouldn't go under 2.6bar
  3. #23
    Oct 2018
    Cairns
    Cold pressure min is just under 40psi and heavy loads should be around 44psi
    40psi is the correct amount of pressure for the 20inch suzuka wheels
