Page 65 of 69 FirstFirst ... 15556364656667 ... LastLast
Results 641 to 650 of 681
Thread: Traffic Jam Assist
  1. #641
    Pacific Paradise QLD
    Traffic Jam Assist will only work if you have ACC and lane assist enabled and then it will work all the time. Thats what I have found out by reading the manual for my MY19 on page 181
    Presumably it is correct but havent been out to try it this week
  2. #642
    Dec 2010
    Helensburgh
    You also need to drive the car faster than 70kph to activate it initially.
  3. #643
    Nov 2017
    NL
    Quote Originally Posted by Ozsko View Post
    Not true. Just turn on acc and drive slower than 70kph. Make sure the road has lines
    Verstuurd vanaf mijn Mi 9 SE met Tapatalk
  4. #644
    Quote Originally Posted by Rainesh View Post
    I’ll find a better road today and see what happens and come back. Thanks!
  5. #645
    Dec 2010
    Helensburgh
    Things have changed, mine was the first car done in Oz.
  6. #646
    An update - worked as described. I turned off Front Assist and Lane Assist and then turned it back on and it appeared to 'wake' everything up. Now the question is how do I stop it bouncing from line to line and stay in the centre of the lane? Thanks for the help!
  7. #647
    Nov 2017
    NL
    Quote Originally Posted by FunkyNose View Post
    Code the intervention point to Early in module A5.
  8. #648
    Perhaps a little help from the driver would do that Its not a system that you allow to take control and just sit there and wait for things to happen
    These systems are driver "aids" not autonomous car controls
  9. #649
    Oct 2015
    The higher your speed and smoother the lines in both sides of your lane, the better lane keep works (think 100kmh and barely any corners)
    Its about the same level of driver ability as a new learner driver. It isn’t a good enough system- yet, to replicate actual human response times and subtlety of judgement/input.
  10. #650
    Dec 2010
    Helensburgh
    If it is ping ponging on a multi lane road something is not right. It will not do sudden changes of directions such as multi lane roads at all unless the car speed is very low and possibly not even then.
