You need to use guided functions and choose parameter upload.
It will not overwrite coding or adaptations.
The part number of my A5 module is 3Q0980654L, but the parameterization file available on VCP is for 3Q0980654H. Can I make the parameterization even though it is different?
I tried to find it, but the only file I have for 3Q0 980 654 L is as follows in the image below. The description is as "MFK Camera config for FW rev L.
But when I open this file in VCP, the following data appears:
I couldn't find the file in the VCP 3Q0 980 654 L file manager for Tiguan. I found for Passat 3Q0 980 654 L. Can I use this from Passat or is it not possible?
Just giving a return. I was able to make a parameterization by VCP. I also activated Emergency Assist.
I haven't been able to test much yet, but it seems that everything works perfectly!
I just tried the steps you outlined before with parameterisation in VCP then coding in VCDS but nothing appears to have changed. Did you flash H, or just parametrise L? Any guidance would be great! Thanks!
You wont see any changes. Just check if lane assist is active at speeds below 70km/h (with acc active)
Verstuurd vanaf mijn Mi 9 SE met Tapatalk
It didn’t appear to be. Are the line conditions more “strict” for lower speed? At 70km/h + it works flawlessly. I haven’t left the car locked and off for a long period after doing it, would that make any difference? Thanks!
What software version do you have and which file did you use? Is adaptive lane guide active?
