Thx for your answer
My camera comes from a tiguan of 2019. It had the TJA functional but on my car it does not work ...
why do you need VCDS or OBD11?
Radar has component protection so just be aware that will need to be addressed if you swap it. Fec also need to be restored.
Thx
Yes I think
How know if my ACC radar is compatible for TJA ?
You tell is necessary have vcds for coding the option after upload the parameters with VCP.. Maybe it's just necessary activate an option in my car with OBD11/VCDS for my new camera, do you think is possible ? and if yes which one ?
my ACC sensor :
5Q0907572G
hardware : H10
software : 0571
My brother has the TJA on his GOLF 7, his ACC sensor is :
5Q0907572H
hardware : H10
software : 0620
thank you
yes I will see with the VCP
what is the coding to do with OBD11 after the vcp?
Hello guys.
I have a Tiguan 2019, with ACC, camera, etc.
I have VCP and VCDS.
To activate TJA, just upload TJA parameters through VCP, and then follow the steps below with VCDS?
A5 > Coding > Byte 16 > set Bit 2-3 to "08" (EA_Variant2)
03 > Coding > Byte 29 > enable Bit 5
13 > Coding > Byte 04 > enable Bit 2
09 > Login: 31347 > Adaption > Channel "Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz" > set to "active"
To upload the parameters, just use the Upload function and select the TJA file?
When you perform the procedure, will all settings in module A5 be maintained or reset?
You need to use guided functions and choose parameter upload.
It will not overwrite coding or adaptations.
