Page 55 of 69 FirstFirst ... 545535455565765 ... LastLast
Results 541 to 550 of 681
Thread: Traffic Jam Assist
  1. #541
    Dec 2010
    Helensburgh
    As far as my (extremely limited) understanding is, adaptive lane guidance setting within the DAP feature 'Advanced Lane Guidance' can give a better experience with lane guidance IF you find that the car is 'ping-ponging' between the lane markers whilst locked in a lane. Intervention (when the car steers for you to adjust lane positioning) can be set to 'early' or 'late' and additionally will give you a new menu option in the car menu.
    I don't know which setting gives a better result, but I think the point is it gives you a little configuration of the feature which from factory is not exposed to the driver.
    Lastly FLA (front light assist) is as far as I know High Beam Assist (HBA). This feature also uses the A5 camera module, but in this case to monitor the road ahead so that high beam is automatically dipped for approaching traffic, or if you approach another vehicle from behind.
    Not to be confused with DLA of course (Dynamic Light Assist) which is effectively HBA+, for vehicles with variable light distribution LED headlamps...
    I'm going to have a aspro and a good lie down, all those acronyms are doing my ancient head in!
  2. #542
    Quote Originally Posted by Ozsko View Post
    So you do have TJA or so it seems. I always forget about turning on ACC as I have never turned mine off since I have owned the car.
    Except for point 1. ? Seems contradictory with point 7.
    With TJA, you can engage ACC at say 70, then use the cruise buttons on the wheel to progressively lower the speed to say 40, and lane guidance will stay active.
    Likewise you can be driving at 30km/s, engage ACC and lane guidance will (provided of course that the road markings are sufficient for the system to pick them up) go active also.
    I'm always confused about this stuff because I don't own an MQB car and I only ever see this stuff for a short while to confirm it's working after activating it.
  3. #543
    Dec 2010
    Helensburgh
    I think turning on the Adaptive Cruise in point 2 is the key. I get confused as I never turn ACC off and can't think why it would need to be turned off.
  4. #544
    Dec 2017
    Castle Hill, NSW
    It's always on, but i had to press "Set" to get it to work.
  5. #545
    Dec 2017
    Castle Hill, NSW
    For me the difference seems to be that Advanced Lane Guidance will always come on automatically above 67kph, whereas for Traffic Jam Assist to work you have to have Adaptive Cruise Control turned on AND you have to press the "Set" button. But I could be a little confused...
  6. #546
    Ok that makes sense.
    If lane guidance is turned on the car menu, it will engage automatically IF above 67km/h.
    But to engage it below 67km/h it needs to be manually invoked by hitting set for ACC.
    This is TJA.
  7. #547
    Dec 2010
    Helensburgh
    Quote Originally Posted by OZROD View Post
    You are correct in that a speed needs to be set. In a moving stream of traffic I usually set the ACC speed to about 10KPH above the speed the traffic is moving at. This keeps the space between my vehicle and the one in front constant as my vehicle is always trying to go faster and the active space setting radar thingy keeps the space if the car in front of me increases speed.
    You now see how confusing it all is, you thought you did not have TJA and suddenly now you have all because VW does a ****ty job at education and we have to learn these things as we go along. My son runs education nights for new owners at the dealer he works for, unfortunately that is another brand but all dealers should be doing this.
  8. #548
    Nov 2016
    canberra
    Hi all,
    dragging up an old thread I came across this ad.
    Traffic Jam Assist activation service - Sydney
    Looks like it can be activated if you have $150 to spare. i also noticed that the new Sportline has TJA.
    What's even more annoying is that the specs brochure from September says ALG and TJA come with the Driver Assistance Package which they definitely did not.
    Hi Ozrod,
    Can't see the link or Ad ????
    Sent from my HTC One M9 using Tapatalk
  9. #549
    Dec 2017
    Castle Hill, NSW
    hey Aus_fas,
    the OP is from kamold and he/she says to send a PM for more info. Just track back to the Original Post.
    Good Luck!
  10. #550
    Mar 2017
    Rang my dealer today asking to enable TJA on my car and was told that TJA is available by default if your car is optioned with DAP on 2018 model but not on 2017 model (which I have). I said it definitely can be enabled on 2017 model (you know, based on this forum). So he is going to double check with the service department and get back to me.
