Page 36 of 69 FirstFirst ... 26343536373846 ... LastLast
Results 351 to 360 of 681
Thread: Traffic Jam Assist
  1. #351
    Aug 2017
    Netherlands
    Quote Originally Posted by NZ_GolfR View Post
    Thanks, I have added yours to the spreadsheet. I am assuming you have TJA enabled on yours (ALG at all speeds when ACC turned on)?
    Once again yours has Byte 13 set to 40 in Module 13 along with all others with TJA enabled so this still looks to be the only way to enable it which needs to be done by VW.
    It could be that VW needs to activate something or some additional coding in another module needs to be done together with this byte?
  2. #352
    Aug 2017
    Uk
    Nz_golfr did you also change byte 6 and 13 in the ACC module? Sorry to keep asking but you don't seem to answer this
  3. #353
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by Jap View Post
    Yes I tried Byte 6 but this made no difference. As I have already mentioned, as soon as I change Byte 13 on mine I get a warning up on the AID saying Front Assist not available and a fault is logged stating "Control module incorrectly coded".
    Looking at the coding of Byte 13 and the change that is made by going from 30 (Bit 4 & Bit 5 Enabled Only) to 40 (Bit 6 Enabled Only) it changes SWaP_FSID_group_3 from 3 to 4. To me this says that TJA is in fact a Software as Product (SWAP) upgrade and as such only done by VW.
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  4. #354
    Aug 2017
    Uk
    Ah, excellent, I did see something about what upgrades had been done in the car (just a list of numbers), I think by pressing and holing the menu button and at the time was wondering if it was a list of SWAP firmwares
  5. #355
    Aug 2017
    Uk
    Just checked, I have 11 "function enabled codes (SwAp)" presume it could be one of them then
  6. #356
    May 2017
    Where did you see the list?
  7. #357
    Aug 2016
    Auckland, NZ
    Just checked mine and I only have 10 enabled.
  8. #358
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by sharp View Post
    Push and hold the Menu button on the Infotainment unit then there is an option for SWaP and you can list installed options.
  9. #359
    Aug 2017
    Uk
    Would you like my list? So you can compare to yours?
  10. #360
    Aug 2016
    Auckland, NZ
    Sure.
