Ok, the A3 owner has VCDS, what exactly do we need? I request a full dump of the long coding for module A5, right?
I got this:
In my simple reading, it seems that this module has 0231 firmware which makes sense, and that could mean that the long coding might be our golden ticket?Code:Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb Part No SW: 3Q0 980 654 G HW: 3Q0 980 654 Component: MQB_B_MFK H06 0231 Coding: 0403070300000401012223448048A90098000E200080 Shop #: WSC 06314 790 00021 ASAM Dataset: EV_MFKBoschMQBB 001001 ROD: EV_MFKBoschMQBB.rod VCID: 3B203F9DE3EC5E1F38B-806E
Not sure, NZ_GolfR thinks also adaptation channels might be different but i will get the adaptation channels not before this sunday.
Could it be of any harm for you to make the long coding the same and test if TJA becomes available? (I don't have any clue how VCDS works, just acting as a man in the middle here)
Hi All, as quoted, I took delivery of my new MY18 162TSI (fully loaded) in Australia last week and I can confirm that it has both ALG and TJA.
I think there is some confusion on when/how it actually works and it is different to the Audi system - we need to acknowledge that TJA operates within the limits of the ACC, our Tiguan has a 3 second stop/go function which means you will always have to manually resume if stopped for a long period.
When I tested this I was on an 80km motorway with ACC set, the traffic slowed below 60km and TJA took over by continuing to steer, the ACC remains on as does the Lane Assist with ALG, both icons remain GREEN on the dash to a complete stop... If this stop is long it still requires the driver to manually resume (same as ACC), this is done simply with a light touch of the accelerator or press the resume button on the wheel - the TJA system then continues to steer/accelerate/brake again from standstill by following the car in front.
It's a great feature, I did notice it doesn't activate on suburban roads, and seems ACC needs to be set high or needs to meet certain conditions to operate as TJA.
I hope this helps settles any concerns... Cheers!
MY18 Tiguan 162TSI R-Line, Black, DAP, Sunroof & Tow with APR Stage 2 Tune & DownPipe
Yes and you should be able to activate it below 60km/h also I believe. Sounds like normal ACC with ALG functionality.
