Page 18 of 69 FirstFirst ... 816171819202868 ... LastLast
Results 171 to 180 of 681
Thread: Traffic Jam Assist
  1. #171
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    Hi Adz11
    My gut feel is still negative as I think you need additional modules in the electronic control box. Better minds on this forum can provide more specific info.
    Sent from my SM-G930F using Tapatalk
    Ordered: 2017 build date Tiguan 162 TSI Highline with DAP in Tungsten Silver and rear luggage tray. ETA: late April / Early May. I did not have to wait. I took delivery on 11 March 2017.
  2. #172
    Aug 2017
    Delewin.
    My fear is your probably right, I can only hope. Isdon is going to do some vcds tweaks for me at some point, I might ask him to have a look through and have a play.
  3. #173
    Jul 2017
    Auckland, NZ
    Hi folks. I got the backup of my ACC module done will email those who request it. I have discovered an error in OBDEleven though. When I access long coding on the ACC module and try and change anything I get an “Something went wrong. Try again” error. Going into manual long coding allows me to change options but most of the descriptions are missing ie byte 7 shows only “...”. Only a few of the options in the long coding helper shows up in manual long coding. I am working with OBDEleven on this.
  4. #174
    Jul 2017
    Auckland, NZ
    Quote Originally Posted by Delewin View Post
    Hi AD Z11
    I believe the answer is no as you need a minimum of active cruise control and that only came with the active info display.
    Not so. ACC does not compel AID.
  5. #175
    Dec 2016
    Quote Originally Posted by Hugo_nz View Post
    Quote Originally Posted by azza83
    Hi mate, having spent most of the arvo in the car, I can confirm that it definitely has TJA - as per the manual, there is no option to 'enable/disable', it is simply active when Lane Assist (with ALG) and ACC are operating on the highway and traffic drops below 65km/h... Works perfectly too, brakes and steers to a stop & goes again too!... The new media screen is awesome too - almost the size of an iPad in the dash!
    Very happy with the car and worth the wait!
    He just picked up his my18 Tiguan .
    MY18 Tiguan Highline 162TSI - DSG - Driver Assistance Package Sunroof- R-Line Package - Indium Grey. Oct Delivery
  6. #176
    Oct 2016
    Artarmon, NSW
    Blog Entries
    1
    Hugo are you confusing Cruise Control and Active Cruise Contol?
  7. #177
    Aug 2017
    Netherlands
    I know on my previous car ACC (adaptive cruise control) was available without AID.
  8. #178
    Jul 2017
    Auckland, NZ
    Traffic Jam Assist
    No I am not. ACC and Active Info Display are available exclusive of each other. TJA is not a seprate hardware option as it is part of ACC. Nowhere does VW state that ordering ACC compels the customer to order AID.
  9. #179
    Aug 2017
    Uk
    I had to register to answer this, ok I have a golf 7 facelift and I'm a Pom but don't hold that against me, I might be able to help, so I had the same problem as you (something went wrong), but in the central electronics, and the way I sorted it was clear the app data on the android, then load up obd11 and sign in, then it all worked again, also TJA was a option in one of the packs here in the UK, but my car didn't have it, but my Lane assist today (had tried before and it didn't work under a curtain speed) worked all the way down to a standstill, but my ACC stopped after my car had stopped for 3 seconds and I had to press the res button,
    Hope this helps
  10. #180
    Aug 2017
    Uk
    Quote Originally Posted by GeeMoney View Post
    We had one member that got the TJA enabled, right?
    How did he do that? Must be by the dealer?
    My dealer told me if you did not buy or select the option on getting the car, it's not possible to simply enable it or upgrade later on as the official German VW factory needs to code something in it...
    Could be a bogus story of course to push me off this track to get it enabled.
    If my new Tig does not have it enabled I will contact VW Germany and i'm able and willing to drive to the factory in Germany if I have to. Lets wait and see how they respond to that
    New Zealand member, as I understand their vw group seem to be nicer than vwa
