Page 15 of 69 FirstFirst ... 513141516172565 ... LastLast
Results 141 to 150 of 681
Thread: Traffic Jam Assist
  1. #141
    May 2017
    Quote Originally Posted by Hugo_nz View Post
    Hope this is what you are after:
    OBDeleven data log
    Date: 2017-08-17 07:35
    VIN: XXX
    Car: Volkswagen Tiguan
    Year: 2017
    Body type: SUV
    Engine: CZPA 132 kW (180 HP) 1.984 l
    Mileage: 2171 KM
    01 Engine
    System description: 2.0 R4 TFSI
    Software number: 5NA907115D
    Software version: 0003
    Hardware number: 06L907309B
    Hardware version: H31
    ODX name: EV_ECM20TFS0115NA907115D
    ODX version: 001004
    Long coding: 012500322466050B34100000000000000000000000000000
    Trouble codes:
    No trouble codes found
    02 Transmission
    System description: GSG DQ500
    Software number: 0DL300011P
    Software version: 2002
    Hardware number: 0GC927711G
    Hardware version: H06
    ODX name: EV_TCMDQ500021
    ODX version: 001001
    Long coding: 0014
    Trouble codes:
    03 Brakes
    System description: ESC
    Software number: 5Q0614517CF
    Software version: 0513
    Hardware number: 5Q0614517AD
    Hardware version: H25
    Serial number: 60547000000212
    ODX name: EV_Brake1UDSContiMK100IPB
    ODX version: 036010
    Long coding: 0AEE939A54202373477F070162C64950C92AC4E2E046927D3842500842AA4200002F641A1B13111435351919323200
    Trouble codes:
    08 Air Conditioning
    System description: AC Automat
    Software number: 5NA907044N
    Software version: 4301
    Hardware number: 5NA907044N
    Hardware version: H35
    Serial number: 00000B00427990
    ODX name: EV_ACClimaPrehVW37X
    ODX version: 002023
    Long coding: 0012000420010001110510000010102A
    Trouble codes:
    09 Central Electrics
    System description: BCM MQBAB M+
    Software number: 5Q0937084CF
    Software version: 0236
    Hardware number: 5Q0937084CF
    Hardware version: H34
    Serial number: 02001705401292
    ODX name: EV_BCMMQB
    ODX version: 017001
    Long coding: 000000000000000000000000000000000000000000000000000000000000
    Subsystems:
    System description: 326 RL 161220
    Software version: 0372
    Hardware version: 033
    Serial number: 00000001612140480936
    Long coding: 0E4DDD
    System description: RLHS
    Software version: 0105
    Hardware version: 042
    Serial number: S3Y17M02D28H20M24S43
    Long coding: 00A8DD
    System description: Sensor, DWA
    Software version: 0316
    Hardware version: 005
    Serial number: 000000000ZY1702302H1
    System description: Sirene, DWA
    Software version: 0314
    Serial number: 00000000000068596766
    Trouble codes:
    U112100 - Databus missing message
    Intermittent
    13 Adaptive Cruise Control
    System description: ACCCONTIMQB
    Software number: 2Q0907572J
    Software version: 0156
    Hardware number: 2Q0907572B
    Hardware version: H01
    ODX name: EV_ACCMRRCONTIVW376
    ODX version: 001011
    Long coding: 320047C35CFF8728749C8065304085
    Trouble codes:
    Intermittent
    Intermittent
    15 Airbag
    System description: AirbagVW21
    Software number: 5Q0959655AR
    Software version: 0317
    Hardware number: 5Q0959655AR
    Hardware version: 003
    Serial number: 003TDR2M44P0
    ODX name: EV_AirbaVW20SMEVW37X
    ODX version: 002154
    Long coding: 98CCC0C00C0000005C5400CF008800000065
    Subsystems:
    System description: BeltPretRevFL
    Software version: 1032
    Hardware version: 106
    Serial number: 5NC857705C0044R01464
    Long coding: 80000D
    System description: BeltPretRevFR
    Serial number: 5NC857706C0047R01489
    Long coding: 80000D
    System description: SideSensor_Df
    Software version: 0887
    Hardware version: 001
    Serial number: 35700000000613C81E1I
    Long coding: 2D2D2D
    System description: SideSensor_Pf
    Serial number: 358000000002AA9C122L
    Long coding: 2D2D2D
    System description: SideSensor_Dr
    Software version: 6149
    Hardware version: 000
    Serial number: 3510001B72465B45B493
    Thanks Hugo_nz. I suspect experts would like to see the long coding for Module A5 Front Sensors Driver Assistance System
    NZ_GolfR, I'm happy to send you my non-R-line 162TSI data log if it helps.
  2. #142
    Aug 2016
    Auckland, NZ
    So I decided to email VWNZ today to see what they say about the software update to enable TJA and this is the response I got back:
    "The Traffic Jam Assist became available from Calendar Week 45 2016, 30th October 2016 ~ 5th November 2016.
    Your vehicle was built on Calendar Week 44 2016. This function was never available for this vehicle."
    If this is true then apparently I missed out by a week. Once Hugo_nz manages to get a full scan of the car then I will have a look and compare hardware versions of the different modules, particularly A5, and see if there is any hardware difference, that would be the only thing I could see that would prevent this being enabled on my car.
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  3. #143
    Jul 2017
    Auckland, NZ
    Cant do a full scan tonight but this should help. Coding for ACC and Camera are visible.
    On the plus side I managed to gain access to A5 and completed coding for highbeam assist (non bending led headlights fitted). Will take a drive later to test.
  4. #144
    Aug 2016
    Auckland, NZ
    Thanks, will compare it to mine tonight and see what I can see. When you get a change can you backup each of those modules and send it through so I can see the adaption channels as well.
  5. #145
    May 2017
    Quote Originally Posted by NZ_GolfR View Post
    My hardware numbers and versions are the same as Hugo's. I guess that's a good sign. Apart from codings only difference I have is A5's software version. His 0271, mine 0231.
  6. #146
    Aug 2017
    Vic
    Same as me, software version 231, I just did a scan of mine with obd11
    For some reason though, it thinks it's the older 2011 r line and I can't change it (in the info bit / picture of the older model is showing / apps and gauges seem to have all the older model ones)
    It's not the 2017 one with apps and gauges that you can select in the supported vehicles list. Anyone else have this or know how I can fix it/change it to?
  7. #147
    Aug 2017
    Netherlands
    So things seems to close down now?
    Is it possible to update the module software? From 231 to the newer version?
    I have an Rline and it should have no TJA enabled although my dealer is clear about it the internet states other wise. When my car comes in I will let you know right away and I can make a possible dump too. A friend is having the OBD stuff and VCDS.
  8. #148
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by veew View Post
    Yes please! What did it look like before?
    Here you go: Mk2 Tiguan VCDS Tweaks
  9. #149
    Quote Originally Posted by sharp View Post
    Sharp: been reading these posts with interest - an excellent community exercise. But your revelation is not good!! It suggests that Hugo's had the firmware in his module updated.
    I suspect (fear) that Traffic Jam Assist might be SWAP (SoftWare As Product) - which means that it might need an updated firmware file from VW together with an activation number that specific to the car's VIN.
    I HOPE THAT I'M WRONG!!
  10. #150
    Feb 2017
    SE Melbourne, VIC
    Received my ODB11 today and ran a scan, also seeing same results as Sharp, did enable ALG and the option is visible in the menus now, lets hope Dons suspicions are not correct to get TJA enabled ��
    MY17 Tiguan 162 Highline | DAP | Rline | Pano Sunroof | Pure White
    Stage 2.5 - APR DP, APR Turbo inlet, Muffler delete, IS38 Turbo, APR tune
    MY18 Tiguan 162 Highline AllSpace | Sound & Vision | Sunroof | Blue Silk
