Nice, Hugo, when do you think you will get your OBDeleven?
Tracking my parcel has revealed that my OBDeleven has arrived in NZ I also noticed yesterday that my car has "learned" that I drive slightly to the left side of the lane, and now keeps me thereabouts...no longer ping-ponging between the lines.
Hi folks. How do I do the scan you are all pining after? I messed around with the software a bit tonight. Certainly easer than coding a BMW. Also, I am unable to access coding or adaptions for module A5. I get an error every time, even with the correct access code.
This will give you a basic backup of the modules in the car which will give the long coding for all the modules although it seems that 09 Central Electronics shows long coding with all zeros for some reason. You can also go in and backup each module individually which gives all the adaptions as well.
Traffic Jam Assist
Interesting you can't get into module A5, which access code are you using?
Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
Hope this is what you are after:
OBDeleven data log
Date: 2017-08-17 07:35
VIN: XXX
Car: Volkswagen Tiguan
Year: 2017
Body type: SUV
Engine: CZPA 132 kW (180 HP) 1.984 l
Mileage: 2171 KM
01 Engine
System description: 2.0 R4 TFSI
Software number: 5NA907115D
Software version: 0003
Hardware number: 06L907309B
Hardware version: H31
ODX name: EV_ECM20TFS0115NA907115D
ODX version: 001004
Long coding: 012500322466050B34100000000000000000000000000000
Trouble codes:
No trouble codes found
02 Transmission
System description: GSG DQ500
Software number: 0DL300011P
Software version: 2002
Hardware number: 0GC927711G
Hardware version: H06
ODX name: EV_TCMDQ500021
ODX version: 001001
Long coding: 0014
Trouble codes:
03 Brakes
System description: ESC
Software number: 5Q0614517CF
Software version: 0513
Hardware number: 5Q0614517AD
Hardware version: H25
Serial number: 60547000000212
ODX name: EV_Brake1UDSContiMK100IPB
ODX version: 036010
Long coding: 0AEE939A54202373477F070162C64950C92AC4E2E046927D3842500842AA4200002F641A1B13111435351919323200
Trouble codes:
08 Air Conditioning
System description: AC Automat
Software number: 5NA907044N
Software version: 4301
Hardware number: 5NA907044N
Hardware version: H35
Serial number: 00000B00427990
ODX name: EV_ACClimaPrehVW37X
ODX version: 002023
Long coding: 0012000420010001110510000010102A
Trouble codes:
09 Central Electrics
System description: BCM MQBAB M+
Software number: 5Q0937084CF
Software version: 0236
Hardware number: 5Q0937084CF
Hardware version: H34
Serial number: 02001705401292
ODX name: EV_BCMMQB
ODX version: 017001
Long coding: 000000000000000000000000000000000000000000000000000000000000
Subsystems:
System description: 326 RL 161220
Software version: 0372
Hardware version: 033
Serial number: 00000001612140480936
Long coding: 0E4DDD
System description: RLHS
Software version: 0105
Hardware version: 042
Serial number: S3Y17M02D28H20M24S43
Long coding: 00A8DD
System description: Sensor, DWA
Software version: 0316
Hardware version: 005
Serial number: 000000000ZY1702302H1
System description: Sirene, DWA
Software version: 0314
Serial number: 00000000000068596766
Trouble codes:
U112100 - Databus missing message
Intermittent
13 Adaptive Cruise Control
System description: ACCCONTIMQB
Software number: 2Q0907572J
Software version: 0156
Hardware number: 2Q0907572B
Hardware version: H01
ODX name: EV_ACCMRRCONTIVW376
ODX version: 001011
Long coding: 320047C35CFF8728749C8065304085
Trouble codes:
Intermittent
Intermittent
15 Airbag
System description: AirbagVW21
Software number: 5Q0959655AR
Software version: 0317
Hardware number: 5Q0959655AR
Hardware version: 003
Serial number: 003TDR2M44P0
ODX name: EV_AirbaVW20SMEVW37X
ODX version: 002154
Long coding: 98CCC0C00C0000005C5400CF008800000065
Subsystems:
System description: BeltPretRevFL
Software version: 1032
Hardware version: 106
Serial number: 5NC857705C0044R01464
Long coding: 80000D
System description: BeltPretRevFR
Serial number: 5NC857706C0047R01489
Long coding: 80000D
System description: SideSensor_Df
Software version: 0887
Hardware version: 001
Serial number: 35700000000613C81E1I
Long coding: 2D2D2D
System description: SideSensor_Pf
Serial number: 358000000002AA9C122L
Long coding: 2D2D2D
System description: SideSensor_Dr
Software version: 6149
Hardware version: 000
Serial number: 3510001B72465B45B493
Thanks, I am assuming there was more to this as there should have been a lot more modules but might be too much to list on a single post. I can already see some differences in the long coding of some of the modules compared to mine already I see yours isn't an R-Line so it will make it a bit more difficult to compare the differences.
I'll send you a PM with my email address and you can email me the full list if it is easier.
