Trailer Assist VCDS/OBD 11 - Camera Obstructed
Hi everyone
I had a VW genuine tow ball and module installed late last year. I activated trailer assist shortly after having it installed but didn't get an opportunity to test it until now.
When I connect a trailer to the car and select the reverse gear I'm prompted to select park assist to engage the trailer assist functionality. When I press the park assist button I see the control instructions on my AID only briefly followed by an error saying "Steering intervention stopped - camera obstructed".
I followed the below instructions.
Enable Trailer Assist
Enables ‘Trailer Assist’ option under the headunit settings.
Select Park Assist Module (76)
Coding
Byte 0, Tick Bit 3
Select Instruments Module
Coding
Byte 12, Tick Bit 5
Select Reversing Camera Module
Coding
Byte 10, Tick Bit 3
I had a search of the forum and saw some other members who had the same issue but there's no mention of their fix, if the issue was ever fixed.
For those of you with a Mk2 Tiguan, have you had any success activating trailer assist?
MY19.5 Tiguan Highline/R-Line with Sound & Vision.
MY19.5 Tiguan Highline with R-Line & Sound/Vision
