You also need to drive the car faster than 70kph to activate it initially.
Traffic Jam Assist will only work if you have ACC and lane assist enabled and then it will work all the time. Thats what I have found out by reading the manual for my MY19 on page 181
Presumably it is correct but havent been out to try it this week
An update - worked as described. I turned off Front Assist and Lane Assist and then turned it back on and it appeared to 'wake' everything up. Now the question is how do I stop it bouncing from line to line and stay in the centre of the lane? Thanks for the help!
The higher your speed and smoother the lines in both sides of your lane, the better lane keep works (think 100kmh and barely any corners)
Its about the same level of driver ability as a new learner driver. It isn’t a good enough system- yet, to replicate actual human response times and subtlety of judgement/input.
If it is ping ponging on a multi lane road something is not right. It will not do sudden changes of directions such as multi lane roads at all unless the car speed is very low and possibly not even then.
