And the brand new Adventure I drove yesterday did not have it activated. VWA are saying the dealers have it wrong and the Tiguan will not have it activated and that the dealers should not be telling people it will be. Who are we to believe?
Here in The Netherlands even if you buy a full R-line the TJA is still a seperate option on the list. The official dealer invoice lists all the options with their short codes like in the brochure, and on mine TJA is not on the list. I was also surprised and was too late to change my order as it was already in production and I didn't want to wait another 5 months. So hopefully we can enable it via VCDS soon as I do have all the camera's etc. needed to work. Or my dealer is wrong and from MY18 onward, TJA is default enabled (rumors, not confirmed yet) I can confirm it within 2-3 weeks as I do have the MY18 build.
Jap.
Did you golf come with acc,or are you saying after you cleared app data you then managed to activate it. Also does your golf have aid..
'cheers.
Yes my golf came with ACC, AID, front assist, rear assist, side assist, trailer assist, lane assist, light assist, park assist, discover pro and road sign recognition,
I didn't activate it, just every now and again lane assist works down to 0mph, it seems to be motorways do it and A roads don't
Mods I have tried/done is
Seat belt warning
VIM
Needle sweep
DRL in MMI
Change colour on AID to yellow
Change colour on AID to red (gti)
Change dials on AID to different design
Change boot logos on MMI to all 10 different types (gti changes all the blue lines to Red to match AID)
Added fuel fill level
Tried 5 brake lights but found out that only the drivers side is wired, which is the fog light, plus it doesn't go all the way across, only the inner of the inner light has LEDs in
Tried enabling the reverse camera (it uses it on trailer assist for measuring angles) but only managed to get it to open in reverse because when I took the trim off there was no video feed wire (still need to order one)
Stop/start deactivate (tested that it would accept 12v for a fellow owner)
Are some others but can't remember ha ha ha
I had to clear app data so that I could get into central electrics as it locked me out (kept coming up "something went wrong")
Hope that helps
Unfortunately, bad news.
As user "veew" has tested, his MY18 does not have TJA. I repeat, it does NOT have TJA enabled. Real bummer, we really need to get the long codings to test guy's. How are the dumps and analyses doing?
