Chains should always be attached to the bar thats solidly attached to the car Never to the hitch or in Westfalias case the detachable part.
Brake safe cables should be attached to the car and not the towbar at all.. I know of a van on a Prado that the cast tongue piece snapped and the van ran back down a hill towball chains and all. Those bars were modified after that
So I finally got a hold of a tow bar kit. Does anyone know what the long coding is for VCDS?
The manual shared only shows the instructions for the online tool (ODIS) the dealer would use.
Check the list here; Tow Bar for the Tiguan
A screenshot here: Trailer Hitch Retrofitting (5N) - Ross-Tech Wiki for adding the module.
132TSI Tiguan Allspace
I did it with my old one, which is the micro-CAN UC with USB. Am planning on upgrading though.
Thanks again. Yea I'll be looking to do the same since all our VWs are later models now.
Just installed an oem tow bar and after connecting the canbus connector under the dash, the vehicle has disabled all assistance systems.
Anyone had this before? Will programming sort the issue?
You need to toggle some bits using vag com. See post #275.
