Originally Posted by
Ozsko
I can't find anywhere that VW has said that the older vehicles when fitted with the new tow bar do not comply so by omission they are sanctioning the change. Can you show me where VW have put a rider on the older vehicles when it is fitted with a new tow bar? BTW I am playing the devils advocate here and nothing more. Has anyone seen a tech bulletin saying to dealers that owners must be warned of the limits of different vehicles when fitted with the 200kg tow bar? If not then VW are condoning the new weight limit on older vehicles and Toyotas are not VW's.
The same rules apply to all makes and the point you dont seem to accept is that unless VW actually publish an alteration to the model specs the original still applies as it did with the Toyota.
Just because they make something that fits on a vehicle but exceeds its design parameters does not make it right or legal.
DMN went in and bought a bar that fitted, certainly but to put it on a prev model that has a lighter limit may not make it legal.
Only VW can answer the question truthfully.
They dont have to put a rider or anything on the older vehicles They have stated its limit and havent changed it to accommodate a newer accessorry and by not doing that they have left the limit the same as it was.
The numpty in spares probably is only interested in the fact that it fits and thats it.
He is not there to tell you whats what, its up to owners to ensure their vehicle is legal and compliant
