Since when did this become a p1ssing contest?
Ok. Well that’s poor design. I’d say it’s because you have a non OEM bar that may sit out further than the OEM bar. It makes no sense that the sensor would howl away constantly while your trying to back the car onto the trailer. Knowing how particular za Germans are about these things, they’d be mortified by that outcome.
It may also detect the bar fitted by VW. Which, as I said before, is not really an OEM bar. The car was designed for the European OEM bar, not the poor cuz from NZ.
As I also said before, the towing module detecting a trailer does a lot more than just turning off the sensors. In my car, which is a 2013 model it effects about a dozen different functions of which the rear sensors are but one. I suggest the Tig would have even more given its 5 years newer design. If all you fit is a bike rack then no problem. But if you do borrow a trailer from Bunnings one day you might have an issue.
