Page 7 of 32 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 311
Thread: Tow Bar for the Tiguan
  1. #61
    Nov 2013
    AUS
    Just discovered this tweak to activate trailer assist: stemei.de .Fahrzeugcodierungen .Codierungsservice .Webdesign - Stefan Meier - Trailer Assistent freischalten - Fahrzeug Codierungen, Webdesign
    Addit: Actually, just realised there are no instructions available to activate it.
    For those who have fitted a genuine VW towbar, does your car have the trailer assist function available?
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  2. #62
    Apr 2017
    Beachlands, Auckland
    Hi veew
    I had genuine electrics fitted by dealer and installed a Westfalia towbar myself. Unfortunately in NZ the genuine electrics do not give you Trailer Assist, only adjusts ABS to help overcome trailer sway, plus disables blind spot monitoring. I spoke to several dealers, as I initially thought they had not fully programmed all the options, but they all said they just download a set routine into the CPU provided by VW - no individual parameter changes using VCDS.
  3. #63
    Nov 2013
    AUS
    Just came across this: Mk2 Tiguan VCDS Tweaks
    May be one of the few steps towards activating Trailer Assist.
    Let me know how you guys go.
    Current:
  4. #64
    Apr 2017
    Hi veew
    Just came across these instructions - I have not tried them yet.
    Activate Trailer Assist - VCDSSchweiz
  5. #65
    Nov 2013
    AUS
    Quote Originally Posted by SNOBUM View Post
    Hi veew
    Cheers mate, let me know how you go
    Current:
  6. #66
    Aug 2017
    Uk
    You need a highline reverse camera for trailer assist too (the one where the lines move when you turn the steering wheel in reverse)
  7. #67
    Apr 2017
    Quote Originally Posted by veew View Post
    See my reply to another member:
    Hi Jap
    Please could you post your codings & adaptation channels so I can compare. I followed these instructions on my MY17 Tiguan R-Line:
    I had the genuine trailer electrics installed by dealer, so car knows when trailer plugged in, but Trailer Assist never worked. After altering the above coding & adaptations, I now get a message that Trailer Assist is available and to press the Park Assist button when the car is in reverse - once I do that, a picture flashes up showing how to control via the side mirror selector/adjuster, but then an error message comes up to say take control of the steering wheel as Trailer Assist is not available due to the reversing camera being obscured.
    I have no idea why this error occurs, as the camera is clean, I have removed the jockey wheel & re-routed the trailer plug out of view in-case it is getting confused.
    I did have a problem with the final adaptation change, as Klemme 15 does not appear in the drop down list??
    Any assistance would be greatly appreciated.
    Nov 2013
    AUS
    Cheers for the above. Will post up when I get around to trying it out.
    Came across this: YouTube
    Current:
  9. #69
    Mar 2017
    Perth, WA.
    So what's the latest on tow hitches then? VW OEM or someone else? Are Westfalia still out of the picture? Anyone had one fitted to an R-Line in Perth?
    Back in the VW world with a 2023 T Roc R, Silver with black roof.
  10. #70
    Jul 2017
    Canberra
    Genuine Volkswagen tow bar is $1100.00 that's including wiring harass. perk of knowing Pre Delivery mechanic is 300 fitted
    SOLD BLUE MY12 GOLF R MK6 APR STAGE 2+ SOLD
    WHITE MY18 GOLF R MK7.5 WOLFSBURG
    WHITE MY18 TIGUAN R LINE PACK WITH SUNROOF
