Page 27 of 32 FirstFirst ... 172526272829 ... LastLast
Results 261 to 270 of 311
Thread: Tow Bar for the Tiguan
  1. #261
    Mar 2021
    Geelong, VIC
    Doesnt pop out as its simply not there Look up under rear bumper and you can see the rear of the panels. Is like that on mine anyway
    Ahhh! I assumed it must have been a pop out piece but didn’t know for sure as they installed before delivery
    Sent from my iPhone using Tapatalk Pro
    2021 VW Tiguan Allspace Highline 162TSI R-Line (His)
    2018 Ford Escape ST-Line (Hers)
  2. #262
    Pacific Paradise QLD
    Quote Originally Posted by lolcats View Post
    Ha ha you cant see where it SHOULD be but as they cost about $2 each VW saved $2 million by not fitting what you cant see LOL
  3. #263
    Mar 2021
    Geelong, VIC
    Hahah yep 100%! It’s like the leather seats nowadays except for the high end manufacturers… leather on the bits you sit on, pleather or fabric on the sides.
  4. #264
    Jul 2020
    australia
    I can vouch for the VW installed one, neat unit and I like that it’s an OEM part.
    OEM is the westfalia VW dealer is local supplied, as long as it's the OEM wiring kit then your good to go. I did not fancy my bumper being chopped up on the R Line so went full westfalia.
    Tiguan 2017 R Line
  5. #265
    Jun 2014
    Genuine VW towbar for me fitted prior to delivery. I want the ease of the 50mm receiver for my bike racks. I always have the tongue in when not using the rack plus it gives a little bit of protection if someone nudges me from behind. The small cut out on the bumper doesn't bother me at all.
    Those with the westfalia, where do you attach your chains and are they easily accessible?
    Sunshine coast
    Do you have a picture of the cutout?
    132TSI Tiguan Allspace
  7. #267
    Mar 2021
    Geelong, VIC
    Quote Originally Posted by iampivot View Post
  8. #268
    Mar 2021
    Geelong, VIC
    Quote Originally Posted by Broony View Post
    Interesting, I saw that earlier in the post but then saw the sticker on my bar so figured it must also be an OEM part as it has a VW part number on it
  9. #269
    Quote Originally Posted by ACID View Post
    In some jurisdictions you can be fined for leaving tongue in when not towing and yes there are attachmennts for chains but as you will only need one due to weight limitations there is a place for it
  10. #270
    I note that towbar has a ball limit of 200kg BUT what does the vehicle have as limit as most are a lot less than that and thats what governs it.
    Doent matter if the towbar is rated to 5000kg and 500kg ball weight its the vehicles limit that matters
    Even the 162 has graded limits depending on number of passengers according to the supplement in my car
