Hahaha, that’s so insane! They option for Oz destination should be available so you can’t order it.....
Black Wolfy with Panoroof on order - Arriving mid Jan......
Gtechniq Crystal Serum Ultra on my Wolfsburg (courtesy of Dan from The Ultimate Detailer). So far I’m loving the shine! I’ll give it a few more days and see if it holds up.
Mk2 Tiguan Wolfsburg
Wowsers that looks gorgeous! I didn’t know for GTech you needed the infrared heat lamps to bake it in (this is mandatory for Pomponazzi Glass coating)? Did you get the EXO coating too?
Can I ask if you considered Pomponazzi and how much did your GTech coating cost?
Thanks!
Pomponazzi Glass coating from The Ultimate Dealer (same place where Ryngalf got his GTech coating?) of a McLaren.....
YouTube
Pretty much every coating would benefit from sitting under heat lamps for 24 hours to cure it. Many places don’t and the life of the coating suffers as a result.
Most coatings will say not to get it wet for 48 hours. But if it’s properly cured before it leaves the shop it’s even better.
I love how glossy these cars look. What I’m really interested in is how good they look in 3 years and after 100,000km with weekly hand washes.
I believe in putting a ceramic coating on the car to protect the clear coat from bird droppings etc. But for a daily driver that’s going to get a fair amount of wear and tear I’m still to be convinced it’s worth the ~$2k investment to get one of these top coatings professionally applied.
I know some of the local detailers will push cars in/out in a day and you’re lucky if it’s under lamps for 20 minutes.
I guess it’s better than nothing but you generally get what you pay for.
A lot of the time required to do these coatings properly is in the preparation and curing (12-24 hours each). There’s no point putting on a coating over blemishes as they’ll stay in the paint forever. Then if you are going to spend $ and hours in paint prep you need to spend the time curing the product after it’s been applied. Otherwise you may as well not bothered.
It ends up being a very labour intensive process and taking 2-3 days to do “properly”. If they take short cuts it’s going to be cheaper but then you end up with a so-so job.
