Results 1 to 3 of 3
Thread: Tiguan R Leather Seats Retrofit?
    Nov 2023
    Ramsgate, NSW
    Hi all,
    I've recently installed Tiguan R seats (electric seats, memory seat function, heated seats, and the TVs at rear seat)
    Electrician came past and hooked them up for me, the electric seat functions worked for 5 min and then stopped working. Didn't test anything else because they stopped working before I could. Electrician tested different fuses/bigger fuses and no avail.
    Any advice on how to get these fixed, I have 0 knowledge on coding.
    The seats were from possibly a 2019 Tiguan R and my car is Tiguan MY17 5NA.
    Im sure someone with more electrical knowledge than me will chime in, but on modern cars you cant just swap parts like powered seats over without wiring, electrical component changes and coding. You could 20 years ago perhaps, but not these days.
    If your car came with cloth seats that were not powered from the factory then you will be missing various electrical components required to have this functionality.
    Mornington Peninsula, VIC
    I guess your Electrician only hooked up the power and GND to the seats?, with MQB platform modules, they wake up via a virtual terminal 15 that is sent over the CAN bus the "Klemmen_Status_01".
    By checking the factory wiring diagram for your Tiguan you should find where the CAN lines need to be connected.
    Here is a thread where we had a good discussion on seat retrofitting Electric seat dead after battery test
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
