Results 1 to 6 of 6
Thread: Tiguan R
    Oct 2010
    Southport, Queensland
    Tiguan R
    The ATE ceramic low dust pads are not available for the Tiguan R.
    Does anyone know of a low dust ceramic pad for the R?
    Bockey
    2023 Tiguan R Driver
    Lots of brake manufacturers are now making ceramic pads. I recently fitted Brembo ceramic pads to my Ford Fiesta ST and they are just as good as the ATE Ceramics I had in my Mk7 Golf GTI. I also have ceramic pads in my wifes Audi SQ5 - those are Akebono Euro Ceramics.
    Surely the Tiguan R uses the same brakes as the Mk8 Golf R?? Perhaps the platform is still too new for aftermarket brake pads. You might need to hold out for a year or so.
    Oct 2010
    Thanks Lucas. The Tiguan R uses front discs similar to the Audi S3 and Arteon R.
    Brembo I may have a solution.
    ATE don’t do drilled rotors unfortunately.
    Bockey
    Aug 2021
    Quote Originally Posted by FastGolfR View Post
    There's a good reason for that
    Have a look here. EBC brakes seem to have some pads for the Tiguan R, but it looks like some use a TRW caliper and other use a ZF caliper. The "Redstuff" pads are the ceramic ones. You will need to check what your car has (it will be embossed on the caliper somewhere).
    Page not found - EBC Brakes
    Oct 2010
    Thank you.
    I'll check them out.
    Bockey
