Originally Posted by
Dose Pipe Sutututu
Awesome, thanks Dan!
Will try use the Can/H as the trigger - hopefully it doesn't affect the CAN Bus network lol
The Pioneer TS-WX610A is all installed, very happy with the result. Nice boost to the stock system, has got some real kick now.
The T-Harness whilst tricky to all fit in did the job nicely, was able to tuck in the extra cable/connectors in the space directly above the head unit. Accessories power came from a fuse just like Dan mentioned. Decided on pulling power from the battery through the firewall via a spare grommet, same location as the one on a Mk7 golf - https://www.autoinstruct.com.au/manufacturer/volkswagen/mk7-golf/running-cables-through-the-firewall/ once I found where it came through in the passenger foot well, was relatively straight forward pulling it through (it ended up sitting behind a big bundle of wires).
There is plenty of room for running the cables under the floor trim, started by removing this in the rear passenger seat and then moving forward to the front of the car. Removing the floor LED light connector was straight forward, was a decent connector/wire not a ribbon as some earlier models.
All in all, was not super difficult, just took quite a while as I really took my time and did a fair bit of research looking at Mk7 Golfs for hints along the way.
MY17 Tiguan 162 Highline | DAP | Rline | Pano Sunroof | Pure White
Stage 2.5 - APR DP, APR Turbo inlet, Muffler delete, IS38 Turbo, APR tune
MY18 Tiguan 162 Highline AllSpace | Sound & Vision | Sunroof | Blue Silk
