Currently working with Rob Bliss Exhaust in Queensland to get a decent exhaust system together. Scorpion Downpipe w/ Mid pipe (deletes resonator) to a custom side inlet twin outlet 3in System. This is muffler is very popular for them with GTIs and Rs. This set up has a bit of Drone and Booming, going to try some inserts to get that under control. They're pretty confident that these inserts will be enough and no resonator will be need. Will give on update on Friday.
Sent from my SM-G965F using Tapatalk
He explain, "They are like a reverse cone which we put into the end of the muffler and they basically create a helmholtz chamber in the muffler. Basically it’s designed to bounce sound frequency’s against each other to reduce drone".
