Nice one! Totally transforms the car doesn't it?
IS38 Big Turbo Upgrade Done!!!
My brief to Etuners Motorsport was:
Keep it Quiet (but not too quiet)
Keep it within budget (Total spend of $5,000 including IS38 )
Make it SAFE, and then SAFE again, and then finally KEEP IT SAFE
Then outside of that - go for your life.
The result?
Well when your digital speedo jumps up in increments of 20kph and is struggling to keep up - but then when the car is more than happy to potter around in daily traffic - then you have an amazing SUV.
So I ended up with 228kw, and about 465nm ATW
So we put in:
BMS drop in filter, and removed the snow grate. No other airbox modifications were done.
CTS Turbo Inlet
CTS Downpipe with Hi Flow Cat
IHI IS38 Turbo - New (but had been used) (06K 145 874G)
Stage 3 Engine Tune
Matching DSG Tune
I really like dealing with Gordie. He listened to what I wanted, added his advice, but wasn't over the top in his recommendations. He enjoyed the process just as much as I did I reckon - and was over the moon himself at the end result - a true enthusiast.
Thanks for everyone's input so far to help me make the decision making process easier.
Now for planning the next set of mods...........
2019 MY19.5 Highline (R-Line, S&V, Sunroof)
Stage 3 - Etuners Motorsport - 228wkW, TCU Tune
G Revision IHI IS38, BMS Panel Filter, CTS Turbo Elbow, CTS Downpipe, Dogbone Insert
Dynamic Light Assist (OBD11), Eibach Pro Kit Suspension
Nice one mate...
What boost and air fuel ratios you running?
Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
Gordie says that IS38 sweet spot is 25psi. Not sure on air/fuel ratio - didnt ask.
Alot of people are using CTS dowpipes which i feel are too big at 3.5inches. X-Force do a similar one at 3inches. Would this still be recommended? Planning the build myself, just waiting om right time to pounce om a used is38 which i want to swap out myself.
CTS seem to be the only one's who've made a DP to fit the Tiguan.
Technically any DP that fits a Mk7 Golf R should fit the Tiguan but there may be some manipulation required to get the fitment exactly right.
Sent from my Pixel 3 using Tapatalk
Nice work davman. +100kwaw for a $5k investment is definitely decent bang for buck!
