Page 54 of 87 FirstFirst ... 444525354555664 ... LastLast
Results 531 to 540 of 870
Thread: Tiguan IS38 and Big turbo upgrades
  1. #531
    Quote Originally Posted by dgp View Post
    Beedub, you mention using a custom tuner.
    I have been reading a lot of posts on this forum as I am buying a 162TSI Allspace but have been driving commodores for years. I am quite familiar with tuning the Holdens, am will probably tune the Tiguan.
    My question though, I seem to read a lot about ARP and the like generic tunes. Are there actually tuners out there that have the capability to custom tune these VAG vehicles?
    I am in Victoria if you have any recommendations.
    Custom tuners in Melbourne that specialise in VW/Audi are Etuners Motorsport and Underground Performance. My car is running an Etuners Motorsport tune and Gavin (h1000vw / forum moderator) is partner in Underground Performance so you couldn't really go wrong with either option.
    The off-the-shelf tunes like APR are fine too. Just they won't "guarantee" that their file will work 100% if you don't use their hardware which locks you into relatively expensive hardware options. It'll cost you more but it is guaranteed results. Though their tunes will also work with other hardware except they only test it with their own stuff. Having said that they have a lot of happy customers. I ran an APR tune on my first Tig and it would come on pretty hard and run out of puff over 5,000rpm. It worked with 3rd party hardware (DP, intercooler, intake).
    Jun 2019
    Thanks tigger73, I would prefer a custom tune so will definitely keep this in mind.
  3. #533
    May 2010
    Davman and Veedub... Thanks very much. Great info and exactly what I was after. So I had a look at the goods advised and I think they looked like some good quality parts.
    So have now ordered:
    IS38
    CTS inlet
    CTS DP
    Looking at getting a custom tune I've decided. Getting quotes now.
    Also got some 2 quotes on fitment of turbo and dp. Varied a lot. $900 is where I'm at so far.
    Decided against the APR thing. Too expensive for what you get in my eyes. My last car had an APR HPFP and INTERCOOLER. Nice stuff but so are some of the alternatives. For example the stock cooler should be fine up to 400hp especially when my car is just going to drive around normally with the occasional traffic light GP. Maybe a quarter mile run etc.. if i tracked it different story.
    The shop I called said if I didn't get the intercooler I couldn't get the APR tune for the turbo upgrade. So no go for me going APR, going custom.
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
  4. #534
    Feb 2019
    South Africa
    Out of interest what are you guys doing for drone when fitting DP (catted or catless) with the Oem or golf R rear silencer?
    I am in the process of getting all the bits to fit a catless DP and with this it will remove the center resonator off the car.
    Don’t want a drony car at all. (Allspace 4motion)
  5. #535
    Jan 2019
    My car is booked in for the 12th August. Getting excited now. The Mrs thinks it's going in for a Stage 1 tune and lowering.
    I've had all the stuff below sitting in a mates garage as I've been buying them.
    Mods to be made:
    TTE475 turbo swap
    Racingline R600 Intake, Silicone hose, and High Flow Inlet
    Pod Filter replacement for the foam filter of the R600
    CTS Downpipe with High Flow CAT and CEL eliminator
    Racingline Uprated Lower Engine Mount (aka dogbone)
    Wagner Competition Intercooler Kit
    Racingline Oil Catch Tank & PCV Replacement
    Racingline Oil Cooler Kit
    Autotech High Volume Fuel Pump Upgrade Kit
    RS3 Ignition Coil Packs
    NGK R7437-9 Spark Plugs
    Eibach Pro-Kit Performance Springs
    PTP Lava Turbo Blanket
    Labour and tune will be done by Etuners in Sydney, along with DSG tune to match.
    It's going to be a 3 day exercise.
  6. #536
    Quote Originally Posted by Beedub View Post
    Mods to be made:
    TTE475 turbo swap
    Impressive hardware list mate! Fingers crossed Etuners can get some good power out of the TTE475.
    VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
  7. #537
    Jan 2019
    Thanks. They've got the car for 3 days so they should have enough time to play with it.
  8. #538
    Sep 2011
    Melbourne, Victoria
    Mods to be made:
    TTE475 turbo swap
    Lol at the wife thinking its just going in for stage 1..
    We have all told little white lies like that..
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  9. #539
    May 2010
    That's an awesome list and you must ecstatic! The Tiguan will be such a different beast with all that stuff given how good even just a stage 1 is on these cars.
    As for the wife.. I'm lucky, I can just ask. ��
    Question a few get the RS3 coils.. what's this do? Cleaner burn? Why do we need it?
  10. #540
    Quote Originally Posted by REXman View Post
    There was feedback from the GTI guys that there was a smoother drive and less rough idle after RS3 coils were used. However, electrical testing was done by a US performance company that did not find any performance benefit from changing from OEM to RS3 coils. I just did it at the same time as my spark plugs, just in case. After 12 months, things are still peachy. I’d recommend doing colder plugs if you are tuned/IS38 swapped over the coils though.
