Page 43 of 87 FirstFirst ... 33414243444553 ... LastLast
Results 421 to 430 of 870
Thread: Tiguan IS38 and Big turbo upgrades
  1. #421
    Jan 2019
    My recommendation is to collect all the parts and get the install done at the same time. It’ll work out a lot cheaper in terms of labour cost than doing things but by bit and building it over time.
    You need to pull the DP and intake pipes out to install the turbo so you may as well do all these at the same time rather than paying to install/remove and install again.
    Yeah definitely something I keep thinking about. Besides, I'm pretty sure if I did it bit by bit the wife would start to question why the car needs "servicing" so often.
  2. #422
    Sep 2011
    Melbourne, Victoria
    Quote Originally Posted by Beedub View Post
    VW have alot of recalls is another good excuse..
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  3. #423
    Yes a turbo swap. Either an OEM IS38 or a hybrid, not sure yet.
    I'm looking at a stage 2+ going by my list at the moment.
    CAI, DP (with CAT), upgraded intercooler, HPFP, oil catch can, ignition coil packs, upgraded spark plugs, uprated lower engine mount and torque link, even a turbo blanket!
    Oh and ECU and TCU tunes to match. Looking at going with Etuners in Sydney for all this.
    What is a torque link? Is that a pendulum mount?
    I’m with Tigger73, if the downpipe is out think about doing the turbo at the same time, this will save on labour costs for removing and reinstalling the dp which bolts onto the turbo.
    For tuning, this may also save you on the cost of an additional ECU tune from stage 2 to 2+/3. With all that equipment you are getting, you’d be well placed for an IS38/hybrid/EFR7163 upgrade.
  4. #424
    Jan 2019
    Yeah, same as a pendulum mount.
    Agree on the cost savings for doing everything at once as each ECU tune per stage has it's own cost, and the labour of course.
    Gee that EFR7163 is a big boy.
  5. #425
    Sep 2011
    Melbourne, Victoria
    Quote Originally Posted by Melbourne_Tiggy View Post
    If you go to the same tuner for stage 1 2 or 3 only the 1st tune will cost you over 1k, 2nd and 3rd normally only a few hundred dollars as it actually does not cost over 1k for them to tune your car as its just labour hours.
  6. #426
    Sep 2011
    Melbourne, Victoria
    MK7 R 24hr mods with Revo parts.. Part 1
  7. #427
    Quote Originally Posted by INASNT View Post
    Waiting for part 2 to come out and then the track battle....
    That's the way to do it - go straight from stock to stage 3 in 24 hours.
    Sep 2011
    Melbourne, Victoria
    I like the brake upgrade kit..
  9. #429
    Yes. I think I may be needing these shortly...
    That’s pretty generous of REVO to sponsor all that hardware and software. I’m going to guess that’s around 3.2 sec 0-100 with LC. Traction will be an issue, hope they put on some good tyres.
    VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
