H&R springs inbound in a few week's
With all this increase in horse power are any of you thinking about cornering stability?
I've been slowly putting together a shopping list of items as I wait for my first service to come around before I start spending money and whilst I have lowered springs on my list I've been wondering about sway bars and suspension.
Just putting it out there to see what you lot think.
Want a sway bar asap. Going to visit Harding when he gets some in and compare the Mk7R ones to my factory ones. I'm going to assumes it's the exact same just longer links..
Sent from my SM-G975F using Tapatalk
Most of my shopping list is products from Hardings. I'm quite taken with Racingline.
I’m pretty happy with the stock adapative suspension.....
On my previous k04 Tig I had ST height adjustable suspension, white line front and rear sways, superpro control arms and front and rear end links. Overall handled very well, however ride quality was sacrificed.
I think this time around the most I’d do is sway bars, however the KW DDC suspension is very tempting. I’ve heard good thing’s about H&R also....
VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
My recommendation is to collect all the parts and get the install done at the same time. It’ll work out a lot cheaper in terms of labour cost than doing things but by bit and building it over time.
You need to pull the DP and intake pipes out to install the turbo so you may as well do all these at the same time rather than paying to install/remove and install again.
Yes a turbo swap. Either an OEM IS38 or a hybrid, not sure yet.
I'm looking at a stage 2+ going by my list at the moment.
CAI, DP (with CAT), upgraded intercooler, HPFP, oil catch can, ignition coil packs, upgraded spark plugs, uprated lower engine mount and torque link, even a turbo blanket!
Oh and ECU and TCU tunes to match. Looking at going with Etuners in Sydney for all this.
