Page 36 of 87 FirstFirst ... 2634353637384686 ... LastLast
Results 351 to 360 of 870
Thread: Tiguan IS38 and Big turbo upgrades
  1. #351
    Quote Originally Posted by Psych101 View Post
    Power is exactly the same on those graphs. The difference is the other line. One is showing torque and the other is manifold pressure.
    Ah yes. Thankyou! Helps if you read the axes
    Dotted line from the right vertical axis. Kw v tq. Kw v psi
    All good. Torque does come on sooner but you can see that these turbos don't get onto full boost until ~4,000rpm.
    It would be really interesting to see the same curves for the IS20 and IS38 standard turbos for comparison (tuned and stock).
    Dec 2018
    AU
    Yeah exactly. Although peak torque may come on later with the hybrid is20 or is38, torque may still be higher than, or similar to, stock at lower rpm anyway. It would be good to see if this is the case.
    For example the snail is making 350nm below 3000rpm on the graph above which is stock torque. Would need to do an apples with apples comparison though as a dyno measurement by itself is hardly reliable.
  5. #355
    This was the sort of thing I was looking to find when trying to decide what path to go down but it's really not that easy to find the info. I'm not that concerned about the peak number more the shape of the curve and the rpm that things happen.
    I think you're looking at this from the wrong angle.
    If you look at the graph, regardless of the boost threshold target, you're already making 1 bar of boost by 3000rpm, at 4000rpm you're making 1.75bar of boost.
    People on the internet need to stop look at when a turbo reaches "max" boost at whatever RPM, if that car only had a target boost of 1bar, then you would be saying "wow that's a responsive turbo, it comes on at 3k rpm".
    It's not laggy by any means, if you're fixated by numbers then you'll never be happy. Look at that torque wide torque band, and the very linear power, another reason why tuners/dyno operators don't show RPM - you're just priming your customer's thoughts.
    When I tune cars for people, I don't even bother putting the boost plot. Just power, derived torque and AFR.
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
  7. #357
    Sep 2011
    Melbourne, Victoria
    Tigger do you have a graph of the turbo you got as comparison?
  8. #358
    Quote Originally Posted by INASNT View Post
    All these are for the previous TTE470 with different tuners/cars as the TTE475 which I have has only just been released:
    Tiguan IS38 and Big turbo upgrades-dvx-s3-1-8bar-tte470-98ron_zpsrv3bxe8z-jpg
    Tiguan IS38 and Big turbo upgrades-g7r-dvx-tte470-stock-ex-amp-ic_zpssjavvn2i-jpg
    Tiguan IS38 and Big turbo upgrades-gti-tte470-95-fuel_zpsjfaiookq-jpg
    Tiguan IS38 and Big turbo upgrades-tte470-471ps-540nm_zps71htjhnu-jpg
    Tiguan IS38 and Big turbo upgrades-tte470-cupra-jpg
    Tiguan IS38 and Big turbo upgrades-tte470-mk7r2-png
    Tiguan IS38 and Big turbo upgrades-tte470-mk7r-jpg
    Tiguan IS38 and Big turbo upgrades-tte470-low-boost-jpg
    Tiguan IS38 and Big turbo upgrades-tte470-cupra2-jpg
    Tiguan IS38 and Big turbo upgrades-tte470-s3-jpg
    Tiguan IS38 and Big turbo upgrades-tte470-s32-jpg
    Tiguan IS38 and Big turbo upgrades-tte470-jpg
    And now if you only look At the torque of the 10 or so graphs you've sent, the other dyno graph you so called laggy doesn't look "laggy" anymore does it?
    You can make a turbo come on earlier with cam timing and low ignition timing but you sacrifice torque output.
    Another reason why some tuners cannot be fked printing out RPM vs. MAP
  10. #360
    These ones come on 500-1000rpm sooner which I think should be a benefit to daily drive ability.
    Obviously tuning and other hardware make a difference to the response.
