based on that torque curve, the boost is probably "all in" i.e. at the boost threshold by 3.5k~3.7k
Then again, is that real RPM or derived RPM on that dyno![]()
Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
I've seen the same sorts of curves from other tuners using the same/similar turbo.
Who knows if it's "corrected" RPM based on roller RPMs.
That torque curve seems to drop off quickly after 4500 rpm....maybe the person should have gone a hybrid IS38 rather than hybrid IS20....
Same dyno as ours. It will be ratio. ie, you run the vehicle in the same gear as your intended power run. Drive up to 100kmh, then enter the revs at that speed. Variations in tyres obviously will cause some inaccuracies. Plus the rev counter isn't all that good compared to pulling the engine speed with vcds.
Honestly, that snail 460 is a ripper. I fitted the one in the GTI above. And we've done some in MK7Rs. Very responsive.Alex's 7R just received an interesting... - Underground Performance | Facebook that's a mk7r with a 460 done on UGPs dyno. Def in ratio.
