Confirming the intake hose fits the r600 and also the stock airbox. The Russian Tiguan was running r600 intake, racingline hose and turbo inlet.
I have used a MK7 GTI intake hose, by Ramair, on both my IS20 and IS38 and both fit fine (no kinks/abnormal bends).Note this is on a stock intake box and an APR turbo inlet.
Yes looks like a reasonable difference in length.
I'm going to do the turbo inlet but probably stick with the stock hose because:
1) it allows more engine movement from the expansion joints and causes less stress on the intake which is fixed. APR actually does not warrant their intake if you use silicone hoses and offer a carbon "hose" with a flexible coupling:
2) nobody has proven that the stock hose is actually worse/gains for using another hose.
Racingline recommend using the intake hose with the r600 and refer to “power gains” although no dyno gains are listed. Its silicone so should flex with some minor engine movement. Although tiguan isn’t listed in terms of confirmed applications.
Racingline intake hose for r600 or stock intake
Revo dynoed their inlet, panel and hose combo and got a 12whp and 15nm increase, not sure what specifically can be attributed to the hose though.
Revo intake hose
Contacted Ramair, replacing as they believe it's defected.
Sent from my SM-G965F using Tapatalk
Review of TCU launch control at 4500 RPM
So I had a chance this morning to try out the revised launch control of 4500 RPM. The sound is a bit more aggressive (rally car sounding) at 4500, compared to previous 4000. There is a lot more drama and wheel spin launching at this rev, the car spun its front wheels for what felt like 1/2 a second before taking off, and there was also a very hard/rough noise when the haldex engaged and transferred the power to the rear wheels. I suspect that if this was done frequently I would be breaking something in the driveline.
The 0-100 time reflected this being a few tenths slower than my PB of 4.1s.
I will be reverting to the 4000 RPM limit as this was the most balanced of having the right amount of boost and moderate wheel spin to get you out of the gate and straight into crisp gear changes and the best 0-100 time.
