Page 64 of 87 FirstFirst ... 1454626364656674 ... LastLast
Results 631 to 640 of 870
Thread: Tiguan IS38 and Big turbo upgrades
  1. #631
    Hmmm that sounds pretty dodgy. The seller should have known the condition and made it clear that it was suitable for upgraded internals only.
    As you said lucky the car was where it was when it went and that no major damage was done. A bit of a set-back but that's one of the risks when using second-hand parts.
    On-wards an upwards.
    Nov 2009
    Cook, ACT
    Quote Originally Posted by INASNT View Post
    Update...
    Put the IS38 on Tuesday, noticed a few marks on the compressor wheel and slight comp to housing rub before putting it on that I did not notice when it got delivered, we thought the rub was because there was no oil in the turbo. I was pondering if I should install it, the IS20 was already out so decided to install it and see how it went.
    Once installed oil run through it and car idling or reeving could not hear any rubbing so thought all good.
    First baseline dyno run at 23psi car made 225kw@4 wheels beautiful power curve, then bang!!! and the car stalled!! Restarted the car and huge rattle from the turbo, removed the turbo and exhaust wheel was hanging loose... Luckily it happened on the dyno and not when I was driving the car otherwise might have dropped a bunch of oil down the exhaust and have to find the exhaust wheel in the cat, also could have put bits of metal through the intercooler and into the engine.
    Attachment 47397
    Had to put the stock turbo back on. Now in the process of claiming a refund through paypal for the turbo as clearly there was some damage to it before it was sold......
    Hunt now begins for a replacement..Have found a few options so IS38 still on the cards.
    No góod - better luck with the replacement.
    Keenly watching, and planning for the time to replace our aging Mk1 Tiguan.
  3. #633
    Update...
    Attachment 47397
    Hi Inasnt, sorry to hear that mate, that is some pretty rotten news. Hope your refund with PayPal and the seller goes smoothly. Good to hear that the car/engine is still ok and that it didn’t cause significant damage. If I see an Is38 at a good price I’ll let you know.
    VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
  4. #634
    Sep 2011
    Melbourne, Victoria
    Quote Originally Posted by Melbourne_Tiggy View Post
    Have found a few secondhand options, also looking at new one to avoid possible failure again.
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  5. #635
    Sep 2011
    Melbourne, Victoria
    Got a full refund on my broken turbo, have a IS38 G version from a Mk7.5 going on early December, turbo install will have to wait as will be away for work and on holidays over the next few weeks...
    Was considering a TTE475 which was going cheap second hand but I would be too tempted to add a cooler, Water/Meth Injection and other mods to get the full potential of the TTE if I installed it...
  6. #636
    That’s good news on both fronts! Sounds like it’s coming just in time for Christmas. Be good to hear your experiences with each of the stages including the latest is38 upgrade.
    I’m going in for my 2 year service next week - with around 14 months and 15k km on the IS38. It’s been smooth sailing, after getting over the initial niggles with the O2 sensor CEL.
  7. #637
    Nov 2018
    Gold Coast
    So much good info on this thread. 👍
    Now that I have a new gearbox I will get the Turbo upgrade prioritised. So far it’s just APR tune, res delete, and turbo elbow, next is the DSG tune and then stage 2/Turbo and tune. Love this car, what’s everyone’s take on rubber? Need new boots and interested in hearing experienced opinions. Thanks
  8. #638
    Oct 2019
    canada
    Are the Tigs where you guys are EA888 DSG engines. I'm in canada an they only offer the EA888 B engine with 8sp auto
    Sent from my ONEPLUS A6013 using Tapatalk
  9. #639
    Quote Originally Posted by badgeskins View Post
    Yeap, we are lucky in Australia to get the EA888 gen 3 - 2 litre TSI engine producing 162 kw and 350 nm. This is the engine that is shared with the golf gti. In terms of gear box we get the 7 speed DSG DQ500 MQB that is also used in the AUDI RS3 and TTRS. Launch control is standard and puts a smile on your face every time. A fantastic platform for modification.
  10. #640
    Oct 2019
    canada
    I just became sad... lol. Also found out APR has no tune as of yet for the Gen3.B either.
