Page 35 of 87 FirstFirst ... 2533343536374585 ... LastLast
Results 341 to 350 of 870
Thread: Tiguan IS38 and Big turbo upgrades
  1. #341
    Quote Originally Posted by INASNT View Post
    Snail 460 hybrid dyno numbers on MK7 GTI..
    Attachment 42937
    That is very impressive! Are you thinking about the hybrid route or looking for an RS3FL?
  2. #342
    Great numbers but I'm still a little concerned how late these come on. Seen this with a few tuners that they really only on full boost at 4,000rpm.
    Tiguan IS38 and Big turbo upgrades-mk7-gti-is20-snail-460-jpg
    based on that torque curve, the boost is probably "all in" i.e. at the boost threshold by 3.5k~3.7k
    Then again, is that real RPM or derived RPM on that dyno
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
  4. #344
    I've seen the same sorts of curves from other tuners using the same/similar turbo.
    Who knows if it's "corrected" RPM based on roller RPMs.
    That torque curve seems to drop off quickly after 4500 rpm....maybe the person should have gone a hybrid IS38 rather than hybrid IS20....
  6. #346
    Dec 2010
    Helensburgh
    It certainly would be a dog to tow with.
  7. #347
    Quote Originally Posted by Ozsko View Post
    And not that great as a daily either. That's my main concern with going larger turbo that you end up with a car that is hard to enjoy as a daily driver.
    Same dyno as ours. It will be ratio. ie, you run the vehicle in the same gear as your intended power run. Drive up to 100kmh, then enter the revs at that speed. Variations in tyres obviously will cause some inaccuracies. Plus the rev counter isn't all that good compared to pulling the engine speed with vcds.
    Honestly, that snail 460 is a ripper. I fitted the one in the GTI above. And we've done some in MK7Rs. Very responsive.Alex's 7R just received an interesting... - Underground Performance | Facebook that's a mk7r with a 460 done on UGPs dyno. Def in ratio.
  9. #349
    But should be accurate to within 50-100rpm I would guess??
    And this is where it gets tricky looking at dyno charts. 2 charts same car and the low rpm "response" looks quite different between the 2 runs:
    Tiguan IS38 and Big turbo upgrades-ugp-stage-3-snail460-is20-jpg
    vs.
    Tiguan IS38 and Big turbo upgrades-ugp-stage-3-snail460-is20a-jpg
    not sure whether this is just smoothing or if it does come on this strong at ~3,500rpm
    Dec 2018
    AU
    vs.
    Power is exactly the same on those graphs. The difference is the othe line. One is showing torque and the other is manifold pressure.
