Newer, modern cars all run EGT, IAT, Baro, Wideband O2, Fuel temp sensors, multiple knock sensors, etc. which enables multiple dimensions to both the ignition and fuel tables. Thus if you're smart enough to interpolate the tables for either end of the spectrum then you'll be fine.
Back in the old days yes you would need a map per location however these days there is simply no need with varying dimensions applied on maps with each additional sensor.
Conservative wouldn't be the right term however they wouldn't being putting much timing in to be knock limited.
Then again who knows what these tunes do, could be purely more boost and that's it or same timing more boost and spray more fuel to suppress knock.
I've been trying to find software and hardware that allows me to do my own tuning however haven't been close to anything.
BMW platform you have a few options such as MHD combined with Tuner Studio.
Just by looking at the torque produced they're running higher duty cycles to make the torque "peaky" from boost coming on hard and bleeding off.
The rest of the power would be from timing changes.
Would have been good to see manifold pressure overlaid too and if the ambient temp probe was connected lol
This was only done recently in the last month or so. However the question about APR "generic" tune vs custom tune and the answer is that if the custom tuner knows what they're doing then they can make more power and still do it safely.
There's probably a bigger safety margin in the "generic" tune but an extra ~15kwaw is a decent increase and your bum dyno would definitely feel it. It's similar sort of increase as going from stage 1 to stage 2.
Different tuners have different ways they go about tuning for sure.
It's always what you as a customer are going to be happiest with and there's a range of factors why people go one way vs. another in terms of tuning. Quite often it's not about the peak number but more about service, ongoing support, future mods and ability for the tuner to accommodate, etc.
But nobody would usually complain with a few extra kwaw![]()
In your example that is obvious in the graph for a EA113. I would be interested to see on other modern MQB engines in particular what the differences are for custom tuners vs the global tuners are. At the end of the day, as more people make decisions to tune and that information is published and tested by consumers hopefully this helps others make informed decisions.
