Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Tiguan Higher Flow Air Intake Options
    Dec 2017
    Castle Hill, NSW
    And for those who just want to remove the snow grate, I just did it. Took less than 5 minutes, lifted straight out, and didn't even get my hands dirty. I have no way of knowing if that made any difference, but I figured it couldn't hurt
    Quote Originally Posted by OZROD View Post
    From my testing I think you may get a modest increase. If you also installed a high flow panel filter you’d probably be able to get a measurable difference.
    I think the filter element plays a decent part as well as the more direct flow path with the Racingline intake.
    Confirming a moderate increase. Snow grate removal was tested and there was a 3% increase in CFM:
    Mk7 GTI Stock Airbox Snow Guard Modification
    With a panel filter (AFE in this example) and snow grate removal, there was 5% better flow:
    Mk7 GTI panel filter and snow guard modification
    Turbo Inlet Pipe (TIP) shows some distinct gains over stock (note APR intake did not provide significant flow increase compared to the panel filter and snow grate removal):
    TIP comparison - APR vs panel
    APR intake and APR inlet pipe
    Turbo Inlet pipe shoot out, Burger Motor Sport and MST with elbow take the lead:
    Inlet pipe testing
    The elbow gives a boost also....
    Sep 2011
    Melbourne, Victoria
    Quote Originally Posted by Melbourne_Tiggy View Post
    Inlet pipe testing
    All these also increase intake noise alot.. DV+ also gives nice turbo noises when coming off the throttle.
    If you really want a loud intake, disconnect the airbox and just have the turbo inletpipe, did this to see how it sounded when installing my intake parts...
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
    Oct 2018
    Melbourne, VIC
    Is there a reason you went with racingline as opposed to something else like APR or LEYO?
    Quote Originally Posted by PDMJO View Post
    Yes I chose the Racingline intake for a few reasons.
    Firstly I wanted a closed intake for low noise as opposed to an open/semi-open pod filter.
    Secondly I needed an intake that allowed higher flows. The APR intake is not any better than stock intake with snow grate removal and a high flow panel filter. The Racingline is good for up to 600hp applications which is more than I’ll ever need.
    Third I like the fact that it looks OEM finish. If you didn’t know what the stock airbox looked like you’d think it was factory.
    Downside it is more expensive.
    Oct 2018
    Melbourne, VIC
    Thanks Tigger.
    Looking into one for myself currently, but a bit overwhelmed by the amount of choice.
    Looking a bit deeper, as much as I like the Racing Line intake - it runs, what appears to be a foam filter.
    Are there other products out there that look like OEM but run a cotton pod inside or a larger panel filter? I could get Impossible Fab to make me a custom box, but then it will just look like my jap crap car at home..
    I like the whole looks stock look with euros.
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
    Jan 2019
    I like the look of the Racingline setup, so much that I'm considering the whole package (R600 intake, silicone hose, highflow turbo inlet, and turbo muffler delete) on my Wolfie, but I've seen reports of the foam filter disintegrating. There's a couple of video's on youtube.
    I did find a filter replacement from another company that lets you swap out the foam.
    MST VW-R6 Replacement Air Filter Kit For VW Racing R600
    Quote Originally Posted by Beedub View Post
    Nice work! I think I might look at heading down this path when I need to replace the foam filter. And yes I've seen the pics of filters that have disintegrated possibly through over-oiling??
