It's 4x9 oval offset and 12in long.
Muffler mechanic said he had it for about 3 years on a shelf and was going to install a hot dog res when he remembered the magnaflow.
He claimed the hot dog would sit too low whereas the magna fits just right.
HTH
Sent from my Pixel 3 using Tapatalk
Will a Golf R wagon rear exhaust be the same?
Still haven't got my car but should be picking up an R exhaust Saturday.
So next question -
1) R exhaust with stock resonator valves closed
2) R exhaust with stock resonator valves open
3) R exhaust with resonator delete valves closed
4) R exhaust with resonator delete valves open
5) R exhaust with resonator delete valves switchable
I'm strongly leaning towards 5.
Thoughts?
6. R exhaust with 3 inch downpipe valves open
It really depends how loud you want it.
The Tiguan has a centre muffler at the rear of the stock DP. The Golf R centre muffler is in the catback section.
All the aftermarket DPs are designed for Golf so are just straight pipe after the cat. It depends how f you’re going to install a higher flow DP.
But if you want noise you need to remove both centre mufflers and open the valves. This can be a bit drones especially on cold start so my (personal) preference is to run with valves closed.
If I’m going to go for a run through the hills I’ll open them manually but other than that I’ll keep them closed.
can anyone confirm is the Allspace has the same rear exhaust setup as the 5seater?
2018 Tiguan Allspace TDI DAP+S&V
2010 Mazda RX8 GT
