Leyo Motorsport are clearing stock on their valved / resonated MK7 R / Mk7.5R catback systems. This with the AWE switch path controller may be a perfect combination at the right price 👌🏽
Yes, it’s a plug & play harness, very easy DIY - only mod is to clip the oem power plug, wire the positive & negative to the socket in the boot, remove some trim and run the exhaust valve wires through a grommet under the car - these then just connect straight up with a few zip ties to tidy![]()
MY18 Tiguan 162TSI R-Line, Black, DAP, Sunroof & Tow with APR Stage 2 Tune & DownPipe
Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
12K?! Good lord.
My exhaust sounds like **** since my mods. Thinking of seeing a custom exhaust shop in Sydney to see if I can do 3in all the way to match the DP without introducing drone, and whether there's any performance benefit in doing so.
If not I'll go the Golf R Mk7/7.5 muffler route.
I have done just over 18,000 kms and have noticed the following in my Allspace
Very quiet exhaust from new
At about 7k-8k, it got a little throatier and started to get a little louder
I assume some carbon build up
In the last few weeks, I reckon mine has now started to get an annoying raspy tone/drone with just a bit of throttle once the engine/exhaust starts to get a little warm - say after driving about 10-15mins. Under hard acceleration it sounds fine, and with cruising it's still quiet, but just add a bit of pressure on the accelerator and the new louder tone appears.
Just wondering if having a Stage 1 tune can introduce this because the car is running richer and unburnt fuel is degrading the muffler baffles?
2018 Allspace 162TSI R Line
Stage 1 tune will run leaner as they run very rich from the factory. This is done to cater for the people that may use cheap low octane fuel.
Cant say I get any drones with my stage 2. You should hear nothing with the stock downpipe and rear muffler.
