Can I ask what it set you back and how long did it take?
And do you manually adjust the valves?
Had the pipes slightly angled out in fear of droning, no drone at all. With valves closed nice and quiet for the Mrs, with them open a nice deep rumble. Very happy.
Hi dafidav, 200 for muffler with motors, 400 mod and install. waiting on the arrival of on/off remote exhaust switch to come in. took about 90 min.
Thanks mate
You got a link to the exhaust remote switch?
2019 Tiguan R-Line - IS38 Turbo - Spectuned - X-Force Downpipe - RS7 Spark Plugs - CTS Inlet Elbow - ECS Inlet Pipe - K&N Panel Filter - Golf R Muffler - APR Exhaust Controller - Superpro Rear Swaybar - Digital Dash Retrofitted - 034 Dogbone Mount - DBA T3 Rotors & Pads - Golf R Springs
2” 2.25” 2.5” 2.75” 3” Stainless Steel Electric Exhaust Valve With Fine tunable Remote Control Electronic Switch Kit|Mufflers| - AliExpress
I found these, plug base suits VW motors, readely available and at a better price. when i receive them ill post a video of them operating motors.
Hi team, I had a Golf R exhaust installed on my T-Roc 2 weeks ago. Because of the narrow rear bumper, they had to remove the valves. I have not done a res delete.
Between 1000 - 2000 rpm, the "boomy" sound is unbearable as some others have described.
Ive had a hotdog style res installed today and it's made 0 difference - if anything the problem is worse.
What's my next option? Block off the outside pipes at the muffler?
Thanks in advance!
